Old 10-08-2019, 07:52 AM
aktrapper aktrapper is offline
Antenna Replacement
I know this is going to sound lame - it should be too easy to do, but how do I replace the stereo antenna?
I replaced the missing radio and hooked everything up but couldn't get reception so I pulled the antenna. The end connector was missing and the wire was in the body and too tight to pull through the body panel, I assume it is crimped in place somewhere. Are there any hold-downs or is it just stuck on something?
What do I need to remove under the dash to replace the cable? Is under the dash even the right way to attack this? I've looked everywhere for a tutorial but can't find one and my TSM is still in my cart at BJ's, I need to get it paid for and on the way.
Anyone have a link to a tutorial or how-to? Thanks in advance.
Certified Novice Mechanic...
89 Grand Wagoneer (AMC 360/TF727/NP229)
A work in progress!
Old 10-08-2019, 08:57 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
go to
oljeep.com
click TSM option in menu at left
then pick TSM for your year.
has all the TSM's
dave in NC
Old 10-08-2019, 08:58 AM
SJTD SJTD is offline
As far as I can remember, mine came out the top of the fender. Four screws. Should be evident.
Just remember when you install the new one to have a loop of cable in the fender and have the cable running up to the hole in the kick panel. This causes any water collecting on the cable to drip off rather than run down the cable into the interior.
Sic friatur crustulum
Old 10-08-2019, 11:35 AM
Thanks SJTD,
I was able to remove the actual antenna and base just fine but the cable is hung up in the body somewhere between the base and the radio. I'm wondering the best way yo get the old cable out and the new one in.
A work in progress!
Old 10-08-2019, 11:51 AM
There should be a hole in the kick panel up under the dash that the antenna wire comes though. This goes into the inner fender area that forms the fresh air vents at your feet. The area between the fender is inaccessible, so there can't be a clamp or such in there unless someone pinched the wire when replacing the fender or something similar. If so, I'd probably cut it off and push the remaining cable into the fender, and use a stiff wire to find the route between the cowl-top hole and the hole under the dash.
Here's what it should look like under the dash.
Old 10-08-2019, 12:10 PM
chubbinius's Avatar
Originally Posted by tgreese
There should be a hole in the kick panel up under the dash that the antenna wire comes though. This goes into the inner fender area that forms the fresh air vents at your feet. If you have the wire going through there already, you could use the original wire to pull the new wire through the fender, or pull though a string or smaller wire that can be used to feed through the new antenna wire.
You're a much faster typer than me, Tim. I was just typing along the same line; adding to yours too...check that area for where your antenna wire might be hanging up, aktrapper, sometimes it gets caught on the lip of the hole or on the vent/cover itself if it's run through there.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 10-09-2019, 06:43 AM
Perfect - that's exactly what I needed. Thanks guys!
A work in progress!
Old 10-09-2019, 11:31 AM
When you pull it through, attach a wire or cable or something like a trail of crumbs. Makes is MMMMMUUUuuch easier to install. You pull the old antenna cable out with rope/string/wire attached. Then you attach the new rope/string/wire to the new connector and pull it back down. The first time i tried swapping antennas I had a bear of a time trying to make the corner into the cab...
Old 10-15-2019, 10:28 PM
Pasta_Man Pasta_Man is offline
Hi all - is it possible to replace the antenna without removing the A/C box under the dash? Doesn't look like there's much room there unless I remove the A/C box.
Old 10-16-2019, 11:50 AM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Doubt it, pretty sure it has to be moved out of the way. Don't know what year your's is Pasta_Man, but its not hard to do (at least on the later Jeeps). Most of the screws line the front of the dash and there is one by the blower motor. That's it! You may have to loosen the dash to get it down on the floor, but that's one more bolt at the kick panel on that side, then you should be able to manipulate things how you want.
...not too rusty anymore
Plenty of patina
The others
1926 Dodge Brothers Business Sedan 212 I4-CRANK START
1987 Lincoln Town Car Signature Series-5.0 AOD (WD)
1987 Dodge Dakota LE 3.9, A999, 3.90 gear (DD)
1994 GMC 'Burban 5.7, 4L60E, NP241, 3.42 gear (DD)
2001 Jeep Cherokee 4.0, AW4, NP231, 3.73 (limbo)
Old 10-16-2019, 11:54 AM
ZackN920's Avatar
WOW Look at that wonderful factory caulk job! No wonder why these things are leakers!
Probably why my cowel leaks onto the passenger floor, and of coarse I can't fix it unless I cut the jeep apart
Plenty of patina
The others
Old 10-16-2019, 12:07 PM
Yeah, dropping it on my 79 is a piece of cake, too. 1/4" bolts across the front and the bracket in the back. If you have never done it, you assume it's a big pain and you are going to make a mess but it's not.
I'm with ZackN920; you probably could do it without dropping the A/C but you are avoiding a <5 minute/free job (lowering the A/C) to make another 15 min job take MUCH longer, require MANY more cuss words, and a few bandaids.
Old 10-16-2019, 05:45 PM
Thanks.
I have an '89.
My mechanic recharged the freon recently, and I was worried that lowering the AC unit (wouldn't I need to disconnected the hoses?) would cause me to have to recharge it.
Old 10-17-2019, 08:19 AM
Correct! No need to open the system, remove hoses, or recharge.
Old 10-17-2019, 03:11 PM
Arizona truck - not surprisingly - the floors had some rust. Picture was originally taken to show the leak location. You can seal that gap without cutting the cowl open.
Old 10-18-2019, 01:16 PM
Thanks again, guys. I will tackle this one soon.
BTW - the reason I need to get to the antenna cable is as follows: when I prepped the vehicle for the paint job, I removed the antenna base but then the cable disconnected from the antenna rod base... and it's such a tight fit that I can't reconnect the cable to the base. Even if I had some slack in the cable, I wonder how I'd connect it - maybe soldering?
-Kevin
experience with CB antenna placement and antenna type - recommendations rmorit01 General FSJ Tech 3 11-12-2010 11:02 AM
AM/FM/CB antenna replacement UtilityRob General FSJ Tech 3 04-21-2006 06:45 AM
What CB radio? PostalJeepSS General FSJ Tech 34 09-24-2003 01:00 PM
Antenna Cable Replacement ddpete88 General FSJ Tech 7 08-09-2003 06:31 PM
