Old 10-07-2019, 10:13 AM
vickmorrow64 vickmorrow64 is offline
Vacuum cannister between tranny and transfer case
Anyone know where I can purchase the vacuum cannister. I can dig up a pic - cant seem to find online
Old 10-08-2019, 10:32 PM
78 WIDETRAC's Avatar
Are you talking about the pod the pulls the 229 t-case into 4wd? if so They are hard to find aparently. every 229 t- case has one. should be tons around you''d think.
A member on here or maybe Fsjnetwork makes a shifter to replace it I think.
Old 10-09-2019, 11:32 AM
Or are you talking just the plastic can that goes between the heater motors, cruise control, and QT switch?
Old 10-09-2019, 11:49 AM
What you're looking for that control the vac shift 229 tcase are called vacuum 'motors'. Canisters are the EPA fuel vapor anti-airpolution boxes/filters(plastic cans) for the fuel system. BJ's Offroad used to sell the vac motors for the 229 tcase. Don't know if they still do?
Old 10-14-2019, 07:57 PM
I found a used one
Tranny of transfer case issue? vickmorrow64 General FSJ Tech 8 08-14-2017 06:37 AM
Tranny problem or Transfer case issue? d_saum General FSJ Tech 8 06-17-2012 09:34 PM
Tranny or Transfer Case Bad???-long Marshmountain General FSJ Tech 4 09-23-2003 03:30 AM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
tranny, transfer case, or diffs - where is the problem? bamaJeepFan General FSJ Tech 2 05-15-2002 12:57 PM
