I have a 88 GW, with AMC 360, & A/C, it has the power steering belt routed around the crank, water pump, and power steering pump. I have gotten rid of the smog pump so that's no there. With my "custom" setup I need to move the power steering belt in order to get the lower rad hose to the radiator. It's not the stock rad so where the hose comes in is quite a bit closer and not angled like the stock rad
not much room between crank and water pump pulleys
Here's what I was thinking. Take off the water pump pulley, slide a shorter v-belt around the pulley and bolt it back on. It the routes it up and out of the way since it's not going around the crank.
My only concern is that I tax my water pump or ps pump. I don't think it will but since I don't know I will defer to FSJ brain trust. If there's any other words of wisdom or pitfalls of this setup please let me know.
Thanks
Thanks
