Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Closed Thread
Old 03-09-2013, 11:59 AM
serehill serehill is offline
Gone,Never Forgotten.
Alrighty them
PM returned.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-09-2013, 02:33 PM
mattparliament's Avatar
mattparliament mattparliament is offline
I'll take a type 1 if it will make it so I can pinch some fingers off!
PM inbound
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
Old 03-09-2013, 04:31 PM
Pm'd you back
You will have to watch your fingeras but it isn't that fast. LOL
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-18-2013, 12:41 PM
RamJetFSJ RamJetFSJ is offline
I tried to PM you but it wouldnt go through. Anyway you can post a photo (or PM me) a shot of the actual wireless remote? Is it a little keychain fob, or what?
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
Old 03-18-2013, 12:49 PM
returned your PM
Originally Posted by Carl78Cher
PM sent I'm looking to get a type 2 tailgate harness and another headlight harness for my 89 Waggy.
Let me know how I can be of assistance
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 05-12-2013, 05:22 PM
Sorry Ramjet I just saw this
There are actually 2 types one clipped on the sun visor & the other is a key fob.
It's actually a winch remote.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 05-07-2015, 03:59 PM
Achilles's Avatar
Achilles Achilles is offline
I just finished my install. I had a few hiccups ( not the harness fault). serehill responded to my request for help Immediately. Outstanding product and service.
Old 05-08-2015, 07:40 AM
I also just finished my install after having it lay around since Christmas. Ive already got a spare motor laying around since Im sure were going to burn this one up putting the window up and down!
I also had a few questions and serehill was quick to reply. Very good guy to deal with.
A little worried about the stops in the bottom of the tail gate now. They visually flex when the window maxes out when going down. When rolling it up, the entire mechanism flexes the tail gate. I've not even tried it with the engine running yet!
I would imagine I have over 8hrs in this tailgate. I replaced all the wipes, the lifter bar cushion, and took the old wiring harness out to rebuild it. I did have to extend the wiring that goes into the interior switch around ~6'. I ended up taking it up the firewall and running it through an existing grommet. I didn't want to drill a new hole.
Click for Video:
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 05-08-2015, 09:17 AM
Great feedback & illustration.
I double checked my pattern & found that somehow I just shorted it on the wire. The wire should have been long enough & the pattern shows to be ling enough. I'm going to build a one off & check it for right length. Other than that there are some great pictures here of the rear switch Mod & mounting of the controller. I know we've spoken & it's doing what it's supposed to.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 05-08-2015, 10:38 AM
Achilles's Avatar
I also had to extend the das wiring too. Thanks JeepJeepster your pictures answered a question I had shot serehill and email about. I am mounted and done. I just have to find the cover in all my mess and reinstall it on the tailgate. Great product, and don't get your finger in the way when it is going up, you might lose them.
Old 05-31-2015, 07:20 PM
redwoody redwoody is offline
dash switch failed
Is there a dash switch with the harnesses?. Thank you.
88 GW hei E-fuel pump 360 rebuilt- rv cam
Old 05-31-2015, 07:25 PM
Achilles's Avatar
You can order it with both dash and tailgate switch.
Old 05-31-2015, 07:32 PM
im assuming prolly not original switch
Old 05-31-2015, 07:37 PM
Achilles's Avatar
No original switch, it has switches that can be easily replaced from auto parts store. Look at the build link in my signature and you can see pictures of the harness an switches. serehill should be in her in short order.
Old 06-28-2015, 08:58 PM
Hey all the original dash switch operates well with wiring rick provides. Just change terminals to fit switch.
Old 12-18-2015, 09:50 PM
Yes you can
You can use the original dash switch if you want to, It's a simple conversion. The save the front switch for a spare.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-19-2016, 08:13 AM
jeepgirl's Avatar
jeepgirl jeepgirl is offline
Are these upgrades still being made? Hope to finally complete this upgrade in the next couple of months. Things came up and unfortunately this project was put on the back burner
Sorry for the delay I built one last weekend. I'm just like the Energizer DUMMY I keep going & going. Pun intended.
"Silly boys.. Jeeps are for girls!"
1978 Cherokee Chief "Ivy"
Old 04-28-2016, 12:58 PM
memo43 memo43 is offline
I am interested in a set up as well. I just completed a complete rewire with an EZ wiring kit.
So I will be starting from scratch I am interested in a type 2.
I will eventually just remove the rear switch completely and have it run from the front only.
Memo
Old 04-28-2016, 03:47 PM
Memo
We can hook you up PM sent. I don't have a tailgate control either.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 07-23-2016, 02:42 PM
Is there one that can unlock the doors and do the tailgate with the same remote?
Closed Thread
Finally got ALL my door locks working!!! YoungClayB Body 13 10-30-2016 12:20 PM
Finally got a speedometer! The_Turd General FSJ Tech 0 01-30-2010 12:48 PM
FINALLY, got around to the rhino/hoodlatch dilemna...(pic heavy) Chuck Brown General FSJ Discussion 7 06-20-2009 12:16 AM
Finally FINALLY 99.9% All Done! Pics Included! Bev25 General FSJ Discussion 53 05-01-2008 05:48 AM
Finally got my 4x4 low!!!! Thanks for the help! gmarblestone General FSJ Tech 1 12-11-2006 11:36 AM
