Old 04-06-2016, 03:49 PM
80Limited 80Limited is offline
Are you using the stock ignition or going msd?
Old 04-07-2016, 10:04 AM
nightglide nightglide is offline
I'm keeping stock till I get it running.......then I molded a duraspark dist that I'm pretty sure will work with the Fitech timing control.
Old 04-12-2016, 04:56 PM
Dr. Marneaus's Avatar
Well Owen, when we installing this bad boy?
Originally Posted by FSJunkie
The Mag - The Wag
Old 04-12-2016, 09:42 PM
I so have project adhd lol. I've gotten half a alarm installed, some fitech installed, a door painted ready to install, a short box conversion, a 65 dash conversion and tonight I installed speakers! Gotta buckle down and finish one thing....hopefully the fitech
Old 05-18-2016, 11:15 PM
Finally
So it's finally installed. So far so good. Runs really smooth. Easy install except for a dumb wiring mistake I may or may not reveal to you guys tomm........
I'll post pics tomm Tho there isn't much to see......
Old 05-19-2016, 10:39 AM
Aww come on…can't be any worse than what I did on my '90 when I first installed the TBI.
Mixed up a wire, and let some smoke out.
Fuel pump wire was tan
O2 sensor ground is tan w/ white stripe.
Tied tan fuel pump wire to ground, when I turned the key 1st time = smoking' wire
Easy fix, but felt pretty stupid that I wasn't more careful.
Old 05-19-2016, 06:10 PM
Everything was hooked up. Turn key, fuel pump primes, tbi primes, turn it over and fires for half a sec running on tbi prime gas. No tach signal. Go over everything. Call fitech. He tells me how to test tach signal on fitech and it's good. He's never heard of a jeep prestolite lol. He says fitech is finicky for tach signal and that ignition might not work!
So angry we race to summit, buy a hei. Race to auto zone for some cheap wires. Race home to install it all. Just about to pull dist and something dawns on me. Check coil wires and sure enough they are wired backwards. Tach signal wire on positive....power wire on neg!
Fix it, turn key fires first revolution lol
Sorry for the novel!
Old 05-19-2016, 06:11 PM
Old 05-19-2016, 06:16 PM
Have some video but not sure how to post em
Old 05-19-2016, 06:18 PM
The clips on my new throttle cable snapped. My buddy Gray had the awesome idea of using a ujoint clip! Lol
Old 05-19-2016, 08:06 PM
https://youtu.be/k85JLHRVWS8
Old 05-19-2016, 08:08 PM
https://youtu.be/GS5DtmnPAOo
Old 05-19-2016, 08:14 PM
Both videos are before temp reached 130......when learning takes over I guess
Old 05-20-2016, 11:42 AM
Looks nice…go drive it already
Old 05-20-2016, 02:45 PM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
Nice. Thanks for sharing your experience with the Fitch product. Looks like a good alternative.
Old 12-06-2016, 09:27 AM
Bump... What did you wind up doing with the supply / return lines?
Old 01-03-2017, 07:26 PM
Abunchahicks Abunchahicks is offline
Noob!
Thanks for sharing this. I'm leaning heavily toward this system for my 87. What intake manifold are you running?
Old 01-15-2017, 09:51 PM
malcoll malcoll is offline
I just installed my GoStreet from FITech... I used the stock supply and return lines. Seems to be sufficient so far. In-tank Walbro fuel pump... bought from Napa, part number AFR E2515....... was able to modify sending unit and all seems to be working as designed. It's "learning" now....
FiTech? 80Limited Fuel Injection 21 03-12-2018 09:32 PM
