Old 05-18-2017, 06:00 PM
KiwiWagoneer KiwiWagoneer is offline
Hood insulation installation - 3m tape?
Hi - what's the best way to put this stuff in?
Guessing there is some wide automotive grade tape, that won't fail under heat.
Cheers,
J.
Old 05-18-2017, 11:41 PM
The factory used a spray on glue, similar to the yellow contact adhesive for carpet and such. probably the same actually.
3M has it in spray cans and it seems to work good.
Old 05-19-2017, 08:47 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
i can confirm it was yellow from the factory.
i have removed OEM insulation from 2 wagoneers
1988 and 1990
you could tell it was sprayed in a wide pattern
and it was indeed yellow.
i am using dynamats hood liner.....
not OEM but better in my opinion
once,...some old fuzzy OEM insulation was hanging down, my carb back fired and the small flame from the carb ignited the OEM insulation.
i did not think it was flammable but the fuzzy strands did burn.
so i think the foil face on dynamats product is nice...for several reasons.
dave in NC
Old 05-19-2017, 01:07 PM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
I have been looking at the dynamite type hood insulation. Let us know what you think after installed. I really wish they would have the stuff in black though. I don't like too much shiny!
Old 06-23-2017, 09:43 PM
Probesport's Avatar
Probesport Probesport is offline
Contact cement sprayed with a primer gun is the proper way. It's often referred to as gorilla snot.
Locally and cheaply, get a $15 gun from harbor freight and a container of Weldwood contact cement from the hardware store. You can use the same for headliners and carpeting as well.
Ken S.
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Old 06-24-2017, 10:59 AM
3M spray adhesive works just fine.
Old 06-30-2017, 12:12 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Remember kids if you spray a nice heavy coat of contact cement on both the hood and the_____________ (whatever you used here), go take a 10-15 min nap, then come back and push the two together, boom! your done. Ajax wont take that off..
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 06-30-2017, 12:18 PM
Probesport's Avatar
^^^ Absolutely. I also spray a thin coat after the wait to active and make positioning easier. Nothing will separate that bond.
Ken S.
Megasquirt EFI
Old 07-16-2017, 08:33 PM
asudchiman's Avatar
asudchiman asudchiman is offline
the one I used already had an adhesive backing.
I will see if I can find the link and post it below.
1985 Grand Wagoneer - [Blue]
1990 Grand Wagoneer - [White]
1991 Grand Wagoneer - Vin#...001 [White]
1991 Grand Wagoneer [Hunter Green]
4rd: 2005 Jeep Wrangler LJ (Sold)
3rd: 1987 Grand Wagoneer (Sold)
2nd: 2005 Grand Cherokee Limited 4x4 Hemi (Sold)
1st: 1993 Wrangler Sahara (Sold)
Blogs:
Primary:My Jeep and Me
Old 07-16-2017, 08:38 PM
asudchiman's Avatar
This is what it looked like along with the LEDs I installed.
The product was called:
Dynamat 11905 Hoodliner 32" x 54" x 3/4" Thick Self-Adhesive Sound Deadener
Blogs:
Old 07-17-2017, 09:14 PM
DarkMonohue's Avatar
Shakes hands with danger
Originally Posted by asudchiman
This is what it looked like...
Please check your PMs.
Old 07-18-2017, 10:58 AM
asudchiman's Avatar
ahh -- got it. cut and paste. thx
Blogs:
Old 07-20-2017, 09:32 AM
twmattox twmattox is offline
I was debating using some of the asphalt sound deadening material and reflective insulation. I was mostly worried about heat loosening the asphalt and all of it dropping onto the engine while driving. Anyone have any experience with the heat loosening the glue?
Old 07-20-2017, 09:54 AM
Kaiserjeeps's Avatar
I use Pliobond for heavy duty gluing. It is better than weldwood products.
It is also gas, oil and wind proof. Follow the directions exactly. The max strength is obtained in 7 days. Something to keep in mind.
If you want to glue a rock to a piece of glass. This is the glue for you.
https://www.hannarubbercompany.com/adhesives/pliobond/
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's and a 7
Old 07-21-2017, 06:03 AM
TexasJ10's Avatar
360 AMC
I wouldn't use the asphalt based products under the hood. They are not designed to go there and are typically very heavy. I suspect they are also flammable . Go with the stuff that is designed for engine bay.
hood insulation ideas needed. Kenall General FSJ Tech 31 06-21-2012 04:37 AM
Hood insulation adhesive seventynine General FSJ Discussion 20 06-29-2011 06:24 AM
Mylar hood insulation Tripwire General FSJ Discussion 4 06-20-2011 07:48 PM
Ill try this here - hood insulation and paint Ralph Rogers General FSJ Tech 6 07-31-2007 05:01 PM
Questions on Bodywork/Painting Cont. 4x4n In A Cherokee In Colorado Body 190 08-07-2004 01:50 AM
