Last weekend I had the opportunity to re-engineer the way the control arms are held in place when attached to the slots on the bottom of the rear window. I'm just passing along what I learned.
To start with, the window was stuck in the down position. I referenced the tech archives to tell me how to remove the window from the control arms so that I could replace the motor (I had already determined it was broken from previous troubleshooting sessions). The archive said to remove the retaining clips that secure the control arm studs to the window frame. I did this. There is also a suggestion to buy new clips but I read in another post that you can re-use the old ones. I decided to attempt to re-use the old ones. Well, I lost one and the other wouldn't hold. So, the gears in the noggin started turning and I came up with a solution.
1) I went to the parts store and bought a variety pack of standard type snap rings from the "Help" section ($4.89).
2) I bought a nice pair of snap ring pliers (love the fixes that require me to buy new tools)($11.99).
3) Found some large washers in my garage. These washers were about 1 1/2" in diameter with a small hole which was about 1/2".
4) Drilled out the washer to fit around the stud.
5)* Using my bench grinder, I ground one side flat enough so that the washer would fit perfectly on the stud without rubbing on the window frame.
6)* Ground the top of the washer down a bit so it wasn't as thick.
7) Reassembled window and control arm assembly.
8) Placed washer on top of stud and placed snap ring on top of that in groove that is there for OEM clip.
9) Did the other one, raised and lowered the window about 12 times to be sure it would all hold and, rejoiced at my success.
* If you use a smaller, thinner washer these steps can be eliminated. I used what I could find in the garage.
That's it. For about $16 in parts ($5 if you don't include the purchase of a new tool) you can hava a secure rear window that can be easily disassembled and put back together should it ever fail again in the future. I'm not trying to say "Don't use the OEM clips", I'm just offering an easier, equally reliable alternative. After all, ever try to put an OEM window clip back on?
I hope this will help sombody some day.
