Old 02-04-2010, 08:50 PM
cocurtiss's Avatar
cocurtiss cocurtiss is offline
Whats your most unique modification?
Just wondering, but what is your favorite/most unique modification that you have done to your vehicle? Something that seporates your FSJ from all of the others!
1981 J20
soa/sf
36x12.5x16.5 Goodyear Military oz
no rust!
Status: Top end tore apart
Old 02-04-2010, 09:16 PM
LOL, the first thing that comes to mind is the rear brake line bracket made from a circular saw wrench (stamped steel) on my 88 GW.
Old 02-04-2010, 09:17 PM
x6xdemonx6x's Avatar
x6xdemonx6x x6xdemonx6x is offline
i tried to skinny mine up some so i could fit it in places like my sammy by flipping it on its side and caveing in the drivers side doors does that count??? Wait it was to decrease wind drag...no wait i thought it would be a easy way to remove the wood paneling...or or or or i saw a purty flower and wanted to pick it......its late for me i've had a lot sugar and i'm bored
FREE 91 grand wagoneer 360 2barrel 4" lift 31" tires rebuilt tranny and tcase dana 44 front and rear
TFI upgrade
Old 02-04-2010, 09:38 PM
jtr's Avatar
jtr jtr is offline
Flat bed or Ford drivetrain. Megasquirt fuel injection isn't very common either.
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 02-04-2010, 09:44 PM
vintagetrks's Avatar
Wooden door panels guess thats my most unique mod, but I'm not alone there are others who have done them too.
New Full Size Jeep Nut
90 Grand Wagoneer "Big Mama"
Old 02-04-2010, 09:48 PM
krek's Avatar
krek krek is offline
Perpetually Perplexed
F150 AC vents in my dash...
Old 02-04-2010, 09:49 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
Bolt in replacment NP241C, short TH400 shaft, transfercase swap for my 77 Cherokee.
Mike D.
Old 02-04-2010, 09:53 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
I would have to say the most unique mod I ever made to an FSJ was for adjustable ignition timing from the cab.....
I took a Mico lockable throttle knob and cable from a dead tow truck and installed it under the dash of my 74, the original Blair Jeep Project. I ran it to a fabbed up bracket on the intake and a tab I added to the distributor. I set a min and max timing stop on each side using self tapping screws on the base of the dizzy. I could then change the timing by unlocking the knob and pushing or pulling to advance or retard the distributor.
Hokey, but it worked great......till the loose dizzy helped the timing gears self destruct.
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
Old 02-04-2010, 09:57 PM
cocurtiss's Avatar
Thats Sweet! Is That a FSJ dash, F150, or custom?
1981 J20
soa/sf
no rust!
Old 02-04-2010, 09:59 PM
Originally Posted by cocurtiss
Thats Sweet!
X2 Very SWEET.
Old 02-04-2010, 10:22 PM
gotmike's Avatar
gotmike gotmike is offline
ummmmm.... do i even need to answer that one???...
i suppose my most unique one would be the spotlight custom made out of a 727 landing light and a slide hammer handle... then i took a 3 prong thread on plug and mounted it in the dash with a relay and a switch in the spotlight... when you flip the switch it connects the ground and activates the relay sending power to the light... so the plug is dead unless the light is hooked up and the switch is on...
oh... and it's a 250 watt bulb... so it's bright...
J.E.E.P
Just Everyone Elses Parts!
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Dana 70-HD Rear axle
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=90702
trailer build thread: http://www.ifsja.org/forums/vb/showthread.php?p=1314880&posted=1#post1314880
Old 02-04-2010, 10:36 PM
shackwrrr's Avatar
I am working on megasquirt right now. And Ive done a disc brake conversion in the back. oh and I got a dixie horn lol
Jeepless
In to Turbo crap now
Old 02-04-2010, 10:55 PM
dajeeps's Avatar
dajeeps dajeeps is offline
mine would be the crewcab.
82 wagoneer dd
73 j4000 crewcab project
Old 02-04-2010, 11:42 PM
J20jeepster's Avatar
J20jeepster J20jeepster is offline
Driving lights mounted in grill.
Rom 1:20 : For the invisible things of him from the creation of the world are clearly seen,
being understood by the things that are made, even his eternal power and Godhead; so that they are without excuse:
Old 02-05-2010, 12:13 AM
frank_c frank_c is offline
i'm working on something unique.
83 Waggy
87 J20
99 TJ
05 Crossfire SRT-6
Old 02-05-2010, 12:31 AM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
Transfer case shifter from a 90's chev truck. (Along with the FI 350, trans, and transfer case...)
Randy S.
It's not what you Buy, it's what you Build.
1987 J20 SOLD
1966 Waggy SOLD
1970 Waggy SOLD
1982 Scrambler SOLD
1981 Scrambler - Current Project/Keeper
Old 02-05-2010, 02:19 AM
men in black's Avatar
My custom console, this is version 4 I'm working on version 6
Old 02-05-2010, 02:33 AM
rixcj's Avatar
rixcj rixcj is offline
^ See my avatar... .
Rich
1979 CJ5 with a 401...it goes a short way on a lot of fuel...
401, t-18/d20 twin stick, dana 30, amc20, D.U.I. HEI, Edelbrock Performer intake, Holley 600, ps/pb, 'glass tub, 1 pc tilt nose.
There's a fine line between "hobby" and "mental illness".
Old 02-05-2010, 02:47 AM
Serious Johnson's Avatar
Hmm, can't think of much truly unique. Put a T-18a & 208 in a Wag in place of the silly slushbox -- probably my favorite mod. TBI with an in-tank pump behind the axle -- didn't take much imagination, but I like it. Built 360 that spins 6,600 RPM -- probably not even a good idea. Limited-slip on both ends -- wouldn't do it again. Ferd Probe front seats & Dodge minvan back seat -- maybe unique, but not particularly wonderful. Wink 5-panel mirror -- don't see a lot those on these. Junkyard springs from I don't know what -- that worked out OK I guess.
I guess mine's just a reg'lar ol' Jeep. Wait 'till Charlie rings-in with Crom!
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 02-05-2010, 06:40 AM
draglink's Avatar
draglink draglink is offline
CANT WAIT TILL SPRING so I can put my half doors back on!! By far the most fun/unique upgrade I have done..
'86 GW 6" Rustys, 1 1/2" BJs shackles, 33 BFGs
