What spark plug gap are you running with an hei setup? I reset mine from .035 to .045 the other day and was curious what everyone else was doing.
Plug gap with hei?
Plug gap with hei?
Kaiser - 1981 J20 115" WB - 5.3l/4l60E/np241c/3-link hp60 spooled/Leafs 14-bolt detroit/5.13's/40's
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕTags: None
I usually run anywhere from .05 to .06 depending on brand and their recommendations.BJ's Off-Road
[email protected]
GAP
Originally posted by j20brettWhat spark plug gap are you running with an hei setup? I reset mine from .035 to .045 the other day and was curious what everyone else was doing.
a gap of .050-.055 is about all you need.1985 J-10 Pioneer Longbed 360\208\727 all original 'cept for TFI & locker w/33's
This unit has a 50,000 volt coil...guess ill bump up the gap again.Kaiser - 1981 J20 115" WB - 5.3l/4l60E/np241c/3-link hp60 spooled/Leafs 14-bolt detroit/5.13's/40's
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
A typical Chevrolet with a 350 engine used R45TS plugs gapped at .045 from '76 through at least '84. Ford's recommended plug gap was .042-.046 on nearly all of their V8's. Some late 70's to early '80's Oldsmobiles had a .060 gapMark B. Jones
Originally posted by GrandWag&PrixActually, now that I think about it, that could be either awesome or really terrible.
'79 Cherokee Chief "Junaluska"
.043-.045AMC/Jeep Forum
Custom machined AMC/4X4/Race Parts...www.Bulltear.com
"We offer performance, reliability and customization for your AMC V8"
I found with my setup .043 works great.Paul
1975 Wagoneer DD
360 with large cap ecm controlled HEI, TBI EFI, Comp Cam 260H, Edelbrock Performer Intake, CS130 alt, 4 row radiator, S10 steering box, QT w/LO, WT 3.54 D44 axles. Rancho 9000X's, ~4" lift, Caddy rear discs.
Plug Gap
Just remember electron flow is in the path of least resistance!
The rest of ignition system must be up to the task.
I proved that to myself by running too large of a gap.
The coil arced to the neg pole and burnt thru the coil tower.
I wouldn't have believed it if I didn't see it. (BlasterII coil/MSD 6al box+ MSD Super Conductor wires).....(.055 gap)
All you need is a reliable arc, proper AFR, &timing=explosion.
Many including myself have chased our tail
when one of the above
has been assumed correct.
My latest assumed ignition problem(tail chase) turned out to be a combination of a slightly rich AFR
at idle and too much initial advance.
I hate intermittant misfires!Seek out the authority to share his knowledge, be enlightened and fix it right the first time.
