im in the process of puttin some new wood on and need to remove the fuel fill bezel. it appears i need to disconnect the hoses behind the fender and remove whole unit that connects to the rubber hoses? im assuming i need to be prepared for some fuel to come out of those hoses?
fuel fill bezel
Originally posted by ampsmanim in the process of puttin some new wood on and need to remove the fuel fill bezel. it appears i need to disconnect the hoses behind the fender and remove whole unit that connects to the rubber hoses? im assuming i need to be prepared for some fuel to come out of those hoses?
unless you are parked on a slope with the engine higher than the gas tank with a full tank, it is unlikely that gas will pour out... park on level ground to avoid any issue.Michel
85 Gwag, 229 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
