It's finally cooler down here in Texas to do some work on my '82 Wag. Bear with me as this is a long post.
I recently had the Wag inspected and it failed because the idle was too high at around 1500rpm. I lowered it to pass, but the engine idles roughly and seems likely to stall when the idle is set below 1500rpm. If I have the idle low and start up the engine cold, it will stall and even stalls when coming to a stop without sufficient warm-up time. The engine runs great otherwise when driving around. My impression is the engine should be able to idle at ~600rpm without issues, so I suspect vacuum leaks and other issues.
The PO claims the engine was rebuilt, but the vacuum lines don't match the service manual. Diagram of the 82 vac lines below:
The smog stuff on the exhaust manifolds and the air pump are all gone. Vehicles older than 24 years old in Texas do not have to meet emissions as far as I know. The diagram below is what the vacuum lines on my Wag looks like right now at the moment.
I used a little vacuum pump to check for leaks and the charcoal canister purge holds vacuum so it is OK.
I found that the EGR doesn't hold vacuum so I pulled it out and could tell it's closed so it's not running stuck open at least. I'm able to move the pin up/down by pushing on the diaphragm. Though, the EGR doesn't hold vacuum nor does any vacuum action cause it to move at all so I think it's bad? Any suggestions on a source for a good inexpensive replacement?
I plan to fix the vacuum lines for the EGR by routing it through the dual CTO and the TVS, so the EGR doesn't activate when the engine is cold or it's cold outside. I tested the TVS with the vac pump and it allows vacuum to pass through freely when warm, and then I stuck it in a fridge for a while then did the vac test again and it is closed - the vac doesn't pass through as much so seems OK.
The VSD vac dump valve is long gone - do I need it? Service manual says it's for preventing the EGR from activating when manifold vacuum is low during hard acceleration.
Is there any difference in the 2 ported vacuum ports on the carb? The diagram shows a E and S port and the actual routing to EGR or distributor advance uses the opposite ports.
The 3-port side of the dual CTO valve seems leaky - the top port is supposed to be closed off when engine is cold but right now it doesn't hold vacuum. I think I'll need to replace it if I plan to use it again.
If I understand the service manual correctly about the two CTO valves for distributor advance, the advance receives manifold vacuum when engine temp is below 155F for faster warm up, or when engine is >220F to keep it cooler? "Modified" (ported) vacuum is applied when engine is between 155 and 220F. The nonlinear valve creates a modified vacuum that appears somewhere between ported and manifold when the load is light, so at idle the dist advance receives more vacuum than ported would provide.
Sorry this post is long, but I figure by giving a complete picture of the vacuum lines so I could get better guidance on what I should do about it. My goal is to replace all the vacuum hoses with new ones (suggestions for sources?), get a new EGR and find another dual CTO valve.
Would I have to readjust the timing after all the vacuum lines are redone?
Another thing I'm suspicious is not working is the fast idle cam because the engine doesn't really idle high when first turned on, it just tries to stay at the set idle point I have it on so I usually pump the gas pedal a little to keep the engine running as it warms up. How do I check this fast idle?
