To start out I got this unit used. So my problem could be anything. Straight to the point,
It is hard to start and when it does start it idles good. I have noticed and played with the
fast idle solenoid and when I pull the solenoid up all the way it works great. I have not checked voltage at the solenoid so I have no idea if it is getting proper volage. I know that it works with the tach signal. Now, what wire did you all hook up on the coil? Just making sure I did that right and does this need a full 12volts? again not sure of my voltage.
TPs is good checked with my meter and adjusted to .64 dcv with throttle plate closed. Key in run position and not running.
Okay question 2, when it is running and I give it throttle it backfires through the intake bad, very lean and sometimes the injectors go on and off.....I am thinking the regulator is adjusted to lean but again I am looking for anyother possibilities.
Oh and another question....on wiring the fuel pump red wire to positive and the green wire to ground side of pump? Now it is hard to get the pump to run all the time that way....so if I disconnect the green wire from ground side and ground the pump it runs normal. Now I know the pump is supposed to turn off after a few seconds but once it is turned off what makes it turn on again.
I guess I need to know what the ecu is looking for. I any help is greatly appreciated. Unfortunatley I will not have time to work on it till next weekend. Thanks again.
