there is a weld on caliper adapter, its pretty straight fwd. you can use a 6 bolt rotor from a 76 and up wag, or if you've got 5 bolt a rotor from a 1 7/8" 77-78 cj will work.
don;t forget that you have to change your master cyl to a disc/disc setup otherwise you;ll have major issues with pedal travel
calipers and pads from junkyard as cores, buy new ones at autozone/kragens/pep boys for about $20 loaded with pads. be sure to get the 1 7/8" calipers, mucho more stopping power
in a nutshell:
91+ k1500 4wd front rotors
AA-049A weld-on brackets from A&A mfg
77 chevy 4wd 1/2 ton front calipers,pads, and hoses if yo dont care bout a mechanical E brake.
will cost you less than $150 if you buy everything brand new from the 'Zone
if you want a mechanical e brake,sub chevy front calipers for 77,78ish caddy eldorado rear calipers.this bumps up the above cost around $120. dont get the later,80s caddy calipers theyre smaller and wont fit the AA-049A bracket
ya see, Scott..as soon as i reply, everyone jumps on the band wagon cuz they now i dont have any good advice
i dint like the weld on bracket idea, cuz i mean, its a weld on, i aint that good at welding but maybe u are, so i went to TSM (www.tsmmfg.com) and bought their kit for 250$ and added later Ebrake caddie calipers. its a bolt on kit.
i dint like 2use the same size calipers on the rear as in the front, cuz no OE manufacture has done the same with any longevity, cept maybe for caddie but then that run only lasted 2 yrs. 76-78.
I gotcha Ken. I wasn't disregarding your advice whatsoever, just looking for a slightly cheaper option. I have idolized your Super for some time now, and it was actually what got me goin on mine. I just got a little carried away with the Sawzall I guess. I appreciate everyone's advice ALWAYS.
i foumd a guy on ebay selling a kit looks good and price isn't bad apparently he runs an off road shop i gathered from some pics if i go to ebay i will look and leave name
no prollemo,ken. [img]smile.gif[/img] i wasnt knockin your advice either. i gotta do everythign on an extereme budget,cause im poor
also,i since ive gotten a welder,i dont hardy try and bolt anything together,anymore
when youre fabbin stuff,its way easier to weld than to drill holes and use bolts,as long as youre sure it wont need to come back apart
i used the weld on bracket wheni did mine cause i couldnt afford to buy a decent bolt on bracket,and i couldnt really fab somethin that spaced the caliper correctly without alot of cutting and drilling.so weld on worked well for me [img]smile.gif[/img]
nothin wrong at all with buying a kit if you cant weld,or dont have a welder
Originally posted by Kenall: oh i have a welder, but its only a lincholn stic. i just dont trust my welds on brake pieces, maybe the shocks..but not the brakes
i am going with the bolt on style as i have a good mig but do not trust my welding for any structual parts just yet.
Kenny
2002 Liberty Renegade stock for now
1977 Cherokee 383/th400/d20 recentered hummer wheels, swamper ssr 38/15.5x16.5\'s
1947 CJ-2A 4.3/th350/d18
always in search of solutions to non-exsistant problems
just a thought, but given the way your rig is going, it seems like that rear end is probably not going to be there for long. maybe you want to do some upgrades to the mater cylinder, booster or something like that incase you go to a D60FF or GM14FF down the line? just a thought...
Originally posted by rselina: just a thought, but given the way your rig is going, it seems like that rear end is probably not going to be there for long. maybe you want to do some upgrades to the mater cylinder, booster or something like that incase you go to a D60FF or GM14FF down the line? just a thought...
is there ever a jeep that is truely finished, never to be modified again.
Kenny
