Old 09-14-2018, 03:46 PM
Zorm's Avatar
Zorm Zorm is offline
OT 351w with GT-40 (or 40p) heads
I know its not jeep but I am putting it in my Cherokee, the 351w. Its a non-roller block, 93 I think. Found a set of GT40 and 40p heads in a local junk yard, which one would be better then the stock heads. Not really looking for huge hp, just want better breathing engine.
If I go GT40 or(40p) heads, keep the non roller cam/lifters or do the retro fit to the roller rockers
Also don't know if I want to try and rebuild the MPFI using the Explorer upper intake or just get a 650 Holley with a Edelbrock duel plane 4 bbl intake. Or use the cheby TBI set up I got. I also found a 80's ford LTD with the 5.0 and a real low upper intake.
thanks for any input.
83 Cherokee 4dr WT(axles)
4" lift, 351w in the works
78 Cherokee Chief 304
07 Sea Ray 205
71 F-250 Camper Special 390
HE guides my path, forgives me when I stray and lights my life.
Old 09-14-2018, 06:13 PM
i grabbed gt40 heads when given choice between 2 @ local yard.
the ‘p’ heads have weird plug angle and many posts of interference issues
eventually the 5.0 engine(from ‘90 mustang GT)will go in my ‘68 mustang.
think either work ~same just depends on exhaust setup.
I didn’t want any hassles so went with gt40.
1994 Caprice wagon
Old 09-24-2018, 03:28 PM
brielly's Avatar
brielly brielly is offline
Hey Zorm, what happened to the stroker you were working on?
For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email rrielly@verizon.net
1982 Cherokee Chief 258 6 cyl, T-5, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
Old 09-25-2018, 08:55 PM
Zorm's Avatar
brielly, Still have it, never finished wiring it up. Was going to put in my daughters 03 TJ but she wants to sell the TJ. I might just sell the stroker and all I have for it. I have always wanted to put a 351w in the Cherokee anyway.
07 Sea Ray 205
Are 401 heads better than 360 heads? Hemp General FSJ Discussion 13 03-27-2011 09:59 AM
I'm getting my head(s) examined... dlowrance General FSJ Tech 3 04-24-2009 02:23 PM
360/304 V8 Head Swap Questions - Hi comp / low comp, etc! Greg Taylor General FSJ Tech 10 01-14-2008 07:55 PM
Heads Noticon General FSJ Tech 18 07-14-2007 04:55 PM
Indy Street heads are on! RWC General FSJ Tech 2 03-20-2002 01:19 PM
