Old 09-06-2018, 08:58 AM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
NP208 rebuild stand?
Hey Guys, long time. Back about 10 or 12 years ago, a member had posted up the design plans for a wooden stand for use during rebuilding of the Jeep NP208.
I've done multiple searches with various terms trying to locate that post(s). Anybody have that design plan available to post up again?
Thanks,
Mike
www.j10mike.com
Old 09-06-2018, 04:01 PM
The word you want is "fixture." http://www.frontier.net/%7Emystkblu/NP208_D300_TransferCases.pdf
Old 09-06-2018, 05:11 PM
J10Mike's Avatar
Originally Posted by tgreese
Ah...Bench fixture. Nope, I didn't use those terms. Thanks Tim.
www.j10mike.com
Old 09-06-2018, 07:58 PM
acct21's Avatar
acct21 acct21 is offline
A 228/229 would fit on the 208 fixture, correct? Same case dimensions?
Old 09-06-2018, 10:34 PM
J10Mike's Avatar
I saw that it would also work for the NP219/NP119. I'm thinking the document was created prior to the 228/229 being available in the Waggy's.
www.j10mike.com
Old 09-28-2018, 04:49 PM
RamJetFSJ RamJetFSJ is offline
Just did this. That fixture was a big help. Should be pretty easy to figure out something similar for any TC. Its just a few 2x4s cut to the right lengths and some holes drilled in them for the studs to sit in. Very simple.
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
NP208 interchangeability Strode General FSJ Tech 9 11-24-2011 07:33 PM
TF 727 Rebuild Video & question leostevo General FSJ Tech 2 01-22-2011 11:53 PM
My Experience with using the 2150 GP Sorensen Rebuild Kit scotty1998 General FSJ Tech 4 02-25-2009 07:25 PM
np208 rebuild shop - columbus oh Jim Webb General FSJ Tech 3 01-25-2009 08:01 PM
Rebuild yerself, or let someone else do it? Narnian General FSJ Tech 18 08-01-2003 04:54 AM
