I have some upgrades planned for my 1990 GW. I have searched the database here but still have some questions.
- Install Edelbrock performer intake manifold
- Install 4 BBL carburetor - Holley or Edelbrock depending on ease of installation of the throttle linkage, cruise control, idle compensator for the AC and AT kickdown. I want to make a clean and complete installation.
- GW has headers, 2.5" exhaust, magnaflow and upgraded Engle cam (can't remember the specifics
1.) CFM rating? My search revealed that most use 650 cfm on the Edelbrock but I'm confused on the Holley - 470 or 670?
2.) I assume a phenolic spacer will be needed. Is this available for either carb?
3.)Is there any special brackets needed for the accelerator cable, cruise control, idle compensator for a/c and a/t kickdown.
4.)Is there an idle compensator available for either carb or is there a way to retrofit the one off of the original MC2150?
Tell me how you did it, was it successful, would you do it differently this time.
Pictures, opinions, part numbers etc... Please!
