Old 02-11-2019, 10:10 PM
Full Size Jeeper's Avatar
Need help with wiring for my MSD 6AL box
I need a 12 volt source to power the MSD box on and off such as an ignition switch. can I use the hot wire off the factory coil or one of the wires that connected to the factory distributor? I don't have my main cables in yet, so no way to hook up a battery yet, what wire would be best for that. Thanks in advance, Darin.
1978 Wagoneer
Mods:
Old 02-12-2019, 09:25 AM
one of the duraspark module power wires is hot in run/crank.
coil wire is poor choice
1994 Caprice wagon
Old 02-12-2019, 11:26 AM
Thanks again BabyWag for the help, I will check for 12 volts at those wires once I get the battery in.
1978 Wagoneer
Mods:
Old 02-21-2019, 12:23 AM
I’m pretty sure It’s the fat red with white stripe wire. The other wire (blue I think) has the start/crank signal on it.
Old 02-21-2019, 09:57 AM
nograin's Avatar
nograin nograin is offline
What's wrong with the ignition wire to the coil?
The on/off just powers an internal relay - doesn't draw much and doesn't even need full voltage.
Illustration on the later pages should show the original ignition wire gets removed from the coil positive. The box may even have an isolator tab with connectors. They used to come in the package.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Check out my wiring diagram gte901m General FSJ Tech 32 11-08-2009 09:09 PM
electric fan wiring write up with (with pics) Wagoneerlover General FSJ Tech 43 07-12-2009 07:01 AM
new wiring job (Interior of rig with pics!!) Wagoneerlover General FSJ Tech 21 05-14-2008 06:35 PM
wiring harness (Emergency) Wagoneerlover General FSJ Tech 5 12-19-2005 05:46 AM
