Old 06-28-2010, 05:53 AM
scotty1998's Avatar
scotty1998 scotty1998 is offline
Has this ever happened to you? (Long)
So I'm sitting at the local convenience store on Saturday and left my Waggy idleing with my 11 year old son in the passenger seat. I'm in the checkout line when someone says, "hey, is that you're Jeep out there?" Always getting questions about the rig, I say, "yeah" and look out the window but notice that the Jeep isn't there anymore.
There is was cruising slowly backwards, across the highway on its own. It was like watching a movie, my son decides to bail out and is swinging on the passenger door and the vehicle wacks a street light, pushing the light post backward as the globe unseats and comes crashing down into the roadway.
Thank god the boy was ok. His only comment when asked why he jumped out was...,"I tried to steer it, then tried to get the key out, and then didn't want to get hit in the face with the air bag!" I say, "oh young Alex, there is no airbag in this truck."
At any rate, when I checked whether the truck was in gear, the PRNDL was in the park position but obviously wasn't locked in place. What could cause this? It's never happened before and I certainly don't want it to happen again. Moral of the story is 1) shut the thing off when not in use, 2) use the emergency brake.
Secondly, the rear bumper is bent in about 30 degrees and I have a good sized crease in the rear quarter. The quarter also buckled in down by the exhaust. I think it'll be easy enough to repair the dents and I'll have to get a new bumper. The only problem that I see at the moment though is what happened to the passenger side B-pillar. The impact flexed the upper part of the Jeep where the tailgate and rear window meet the quarter. It split the body weld and pushed out the entire back quarter about 1/4". Now, the tail gate rattles around in the frame and I'm not sure how this can be repaired. I can post pics if it'll help.
Can't help but think, if this was a modern vehicle, I'd be talking about replacing the whole rear end
1987 Jeep Grand Wagoneer
Stock Everything
AMC 360, 2-BBL Motorcraft
Old 06-28-2010, 06:21 AM
slow5 slow5 is offline
I experienced this same issue the other weekend. Have not been able to figure out why it is happening. Needless to say the wagoneer is parked until I do.
Old 06-28-2010, 06:27 AM
scotty1998's Avatar
I always felt that the column was a little "soft" meaning that the gear shifter is a bit sloppy and looseish feeling if that makes any sense. I'm guessing linkage wear?
Stock Everything
Old 06-28-2010, 07:21 AM
710 Burner's Avatar
The bushing in the linkage get worn and produce enough slop that the parking paw does not get set if you aren't paying very close atention. If you put the Mr. Shift kit in the valve body of the TC727 and drilled the passage to allow fluid to pump into the torque converter while in park, it will actually creep forward.
Mark B. Jones
Old 06-28-2010, 07:41 AM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
left the truck running with child in car ???? no E brake ???? WHY ?!?!?!? i dont understand why you did this
Old 06-28-2010, 09:03 AM
scotty1998's Avatar
Yes, I'm certainly not proud of this and the practice is very common in our little podunk area. Life's lesson learned. Someone was definitely looking out for us.
Stock Everything
Old 06-28-2010, 09:13 AM
I had the same problem with mine...bushings in the linkages were shot...got them at a local Chevy dealer but they had to do some lookin...
-Jonny B.
1979 Cherokee Golden Eagle - 4" lift, 33x12.5x15
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-28-2010, 09:16 AM
scotty1998's Avatar
Are the bushings limited to the linkage under the hood or did you have to replace everything all the way back to the tranny? IOW, are they easy to get to?
Stock Everything
Old 06-28-2010, 09:22 AM
idk about the 727 rigs but mine only has 2 bushings and real easy to get to from underneath
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
1984 J10 - Parts
Old 06-28-2010, 09:45 AM
scotty1998's Avatar
Looks like I located the two bushings on the parts catalog. Sound like there's no HELP! part or replacement part # floating around then?
Stock Everything
Old 06-28-2010, 10:01 AM
gsmikie's Avatar
Auto Trannie God
check your eng/trans mount
Old 06-28-2010, 10:17 AM
twmattox twmattox is offline
Help part number 14041
http://www.dormanproducts.com/catalo...nal.pdf#Page=5
Contains the bushings for Chrysler for and GM transmissions...just used them myself about 6-months ago.
Old 06-28-2010, 10:25 AM
scotty1998's Avatar
Sweet. Thank you!
Difficult job or will the old pop right out and the new pop right in?
Also, excuse my ignorance on this but is the tranny mount the same as the engine mount? I know there are two engine mounts in the front but is there a similar one for the trans? Just one mount? Several?
Stock Everything
Old 06-28-2010, 10:37 AM
j20brett's Avatar
j20brett j20brett is offline
Just one rear trans mount. Its at the end of the trans just before the tcase.
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 06-28-2010, 11:31 AM
scotty1998's Avatar
Thanks!
Stock Everything
Old 06-28-2010, 03:00 PM
El_Diablo's Avatar
El_Diablo El_Diablo is offline
theres actually an adjustment procedure that should be performed when things such as this happen... not necessarily bushings
Old 06-28-2010, 03:17 PM
FSJ Guy FSJ Guy is offline
If this was a newer modern vehicle, you would have had a brake-shift interlock and it wouldn't have rolled in the first place.
Glad to hear that no one was hurt.
Ethan Brady
www.bigscaryjeep.com
Old 06-28-2010, 11:08 PM
Gas Pumper's Avatar
Gas Pumper Gas Pumper is offline
X2 on the out of adjustment idea. Your boy would have been able to remove the key if was actually in "park."
FSJ-less...
...at the moment...
Old 06-29-2010, 09:49 AM
El_Diablo's Avatar
not true, the only thing that it would do is make it so it couldn't be shifted without pressing on the brake, most of those systems are actuated by a cable or sensor on the shifter itself so it wouldn't have made a single difference if the cable or actuator was out of adjustment such as in this case
Old 06-29-2010, 11:28 AM
scotty1998's Avatar
I bought the bushing kit as recommended anyway ($6.99). I'm sure they'll likely need it. The column just feels sloppy and my wife has made a comment more than once about whether the thing is actually in drive when it needs to be. You can move the actuator back and forth when you're cruising along such that the indicator on the PRNDL doesn't point accurately to the right gear.
I was playing with it through the gear range last night and it definitely needs something. Sometimes I'm not entirely confident that it parks when needed. This will not be on the road until I find out what the problem is.
Anybody have a link to how to perform the adjustment procedure if not bushings? Would this be in the Haynes Manual?
Stock Everything
What Happened to my NP229 Mxlt General FSJ Tech 9 12-14-2009 06:33 PM
My Long, Hard Quest is over... I now have a Grand Wagoneer! TylerH860 General FSJ Discussion 45 07-31-2009 02:09 AM
Coil Sprung/ Long Arm Wagons? 70sWagoneers General FSJ Tech 2 12-24-2007 09:24 AM
J10 long box interchange? Melan General FSJ Tech 3 10-10-2007 08:54 PM
FSJ Daily Driver Advice (very long post) The PIG Smith General FSJ Discussion 17 09-07-2007 09:15 AM
