I looked around the archives and could not find an answer to this particular problem. I have a '79 Cherokee Chief with Quadratrac, and an '84 Grand Wagoneer with Selec-trac. I have the vacuum operated front axle, and want to put the front QT Dana 44 from the Chief into the Waggy.
I realize that I will lose the 2wd option, but otherwise, is this possible? Do I also need to swap the t-case? The rear axle on the Waggy is an AMC 20, and I could swap the Dana 44 from the Chief if necessary.
Will the low range selector work the same?
Any advice would be welcome. Although I am newly registered, this site has helped me greatly in the past couple years. Thanks in advance for your help!
