I'm trying to get the linkage off the transmission. I'd like to take the pieces and have them powder coated. Any advice on how to get it off? I can't easily figure it out.
Removal of 727 linkage (on the transmission side)
rods just pop off, only held by small bushings
arms on trans. held by pinch bolts, just loosen bolt(s)
pic of arms
Never seen anyone take pics of process so I will since I finally decided to replace them, after years of neglecting the leaky pig. Kind of a PITA, but there are worse jobs on a FSJ. Different ways to do this, I believe this to be easier than crawling around on you back under a FSJ. BE SAFE YOU WILL BE REMOVING THE SHIFTTony
