Good, now your making progress. check float level in carb, is the very thick heat spacer under the carb, is the fuel line resting on a very hot part of the engine? Here in Arizona I always run a electric pump just for the issues your having.
Random Stalling when at Running Temp
Update: No stall on the way to work! Considering it stalled 3 times on my way home last night, I would say that is an improvement.
On my way home last night when it stalled the 3rd time it really didn't want to start back up. I pulled the fuel line on the pump side of the filter and it was bone dry. No gas. So, I assumed there was either a blockage or a bad pump. Since the pump is fairly new and seemed to be working until the car stalled, I started looking for any potential blockage. Nothing notable came out of the lines when I blew them out. I am thinking that the clogged filter on the sending unit is my main culprit.
Anyway. see if enrichening the idle mix helps. If turning the idle mix screws does not effect the idle - then almost certainly the idle passages are gunked up.
The pick up tube in the tank should have a pretty big meshlike filter on it (aka sock).
I understand that this is shorter than the stock sock. I never let the jeep get close to empty.
Had that same issue last year. Tank vents eventually plug (or soft lines from the vents to the charcoal canister collapse), and my tank was building pressure. Really hard to start (think it was from the return line back-pressurizing the feed from the mechanical pump; it was essentially blowing the fuel back into the tank as it sat). Didn't really have stalling issues, but then the tank started leaking out of the vent seals when the tank was full, so I had to pull it all apart and change everything out. New vents and seals solved it all.1990 Grand Wagoneer with HD towing package -- everything works! (for now...)
Fuel Tank
Drop the coffin fuel tank and basically hose it out completely. You'll find crap in there that will shock you. Do it on a Friday and give the tank the weekend to dry out. Also pick up a couple of cans of black flat rustoleum. Good idea to spray the coffin.
Originally posted by babywagx2
The wires can break down internally from decades of flexing.
The "wiggle" test can sometimes replicate the issue.
If testing and stalls a quick ohm reading of the pickup will show infinite resistance(usually).
Pickup assembly is cheap & easy to replace. Can be done w/o removal of the distributor.
Does your 87 have the goofy plastic horseshoe coil connector? That can be an intermittent loss of spark.joe
yep the horseshoe connector on every one I have owned needed replacement.
far as fuel issue just because a part is new doesn't mean it cannot be bad.
aftermarket parts are not great these days. many are poor quality offshore stuff.
a very small debris chunk on inlet side can make a pump nonop.
always best to install a clear plastic filter on pump inletTony
