Pulled this AM/FC/CB at a junkyard today, plugged it in, and no matter how i plug in a speaker i cant get any audio out if it. Not even radio static. I was wondering if its worth getting repaired at a repair shop. If you have had one of these repaired how much did you pay?
AM/FM/CB repair?
Hmm. It does light up so it's getting power. Did you try grounding the case while testing? Also, you need at least the radio antenna hooked up to check properly.My Stable:
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
1997 Volkswagen Cabrio, 2.0L, Manual
2005 Kia Sportage, 2.7L, Auto
2006 Toyota Sienna, 3.3L, Auto
2018 Toyota RAV4, 2.5L, Auto
Recent projects (no longer with us)
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
Originally posted by ZacharyHPulled this AM/FC/CB at a junkyard today, plugged it in, and no matter how i plug in a speaker i cant get any audio out if it. Not even radio static. I was wondering if its worth getting repaired at a repair shop. If you have had one of these repaired how much did you pay?
Those are worth big bucks these days! LOOOOOooots of people want them. I do not know of specific people that work on them but yes, there are companies out there that will fix and upgrade it. They can add USB inputs, bluetooth, RCA outputs, etc. Someone will post some links here after me. If you decide not to fix it, DO NOT throw it away. Post it for sale here in the classifieds; It'll sell. They go for alot on Ebay, too. I have an extra set of factory radio knobs I would sell you (PM me if you need them) for a decent price. I am super extra doubly jealous of your radio/CB!Chuck McTruck 71 J4000
(Chuck McTruck Build Thread)
00 Baby Cherokee
ZacharyH Did you get antenna with the small coil and the splitter for the antenna.
Try testing the radio first. Plug an AM/FM antenna in to the rear for the test. If testing the CB, the SQ (squelch) should be turned all the way down (counterclockwise) and the gain all the way up (clockwise). You should have an AM/FM-CB splitter and plug the cb antenna into the coax connection. You may need to have the microphone plugged in for it to work (even for receiving) depending on how the unit is built.
The speaker cable might have a connection broken inside the unit's case (remove the cover to check). Also check for any fuses internally that might be blown.
