Hi All-
Just an open question to anyone on the wet side of WA WA land.
Any 'greater Seattle area' FSJ'ers have any 327 Vigilante stuff?
Years ago, I had a 67 Wag, 327/TH400/D20. At the time, I took the engine, trans, t-case out as one unit, the 'power pod', so to speak. Plan was to go thru it and rebuild it all.....but it ended up going away, sadly.
I realize this is pretty uncommon to ask for, most have probably been trashed or scrapped. But it is my fave engine, and would like to have another someday before dirt nap time.
If one could be found, it would have to be rebuildable- no cracked block or heads, or fried rotating assembly....and no wiped out cam. All the adapter pieces would be needed, too- if perhaps the engine/trans/starter had been disassembled. Engine and trans mounts, manifolds and air cleaner too.
I've seen a few since I had mine, but they ended up being junk...sadly, quite a few dishonest folks out there hocking parts these days. Hope to find a good and honest FSJ'er instead, to deal with.
Thanks for listening.
