Old 05-17-2019, 09:30 AM
I had all sorts of fun changing out the casting plug in the rear of the drivers side head....
Some said they cut a hole in the firewall but I was NOT going to do that.
Ended up using a battery powered ratchet to put a large self tapping screw in the casting plug. Put some vice grips on the screw then used a small pry bar to pop it out. Was able to use a small sledge hammer to tap tap tap tap it back in.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Need help! Spark Plug Question for 1980 Cherokee flippindiscs General FSJ Tech 10 04-25-2011 06:47 AM
freeze plug replacement ?s and or advice 3nellieb General FSJ Tech 4 08-26-2010 10:55 PM
Freeze plug jeepjseries General FSJ Tech 5 01-16-2010 07:34 PM
freeze plug mark General FSJ Tech 1 09-11-2005 06:20 AM
freeze plug problem ArtsiFrtsi General FSJ Tech 3 04-09-2002 07:09 AM
