Hello everyone, before I begin i would like to say that I have been digging through the forums about this for a few weeks now and haven't been able to put my finger on this problem. I have recently purchased a 1989 grand wagoneer with the amc 360 in it. Here are a list of repairs the Previous owner has done:
p { margin-bottom: 0.1in; line-height: 120%; }
05/07/2007: autozone remanufactured starter
05/31/2008: autozone duralast gold battery
07/22/06: napa 18731 rear axle main seal x2, BR10 rear wheel bearing x2, gear oil,
10/31/07 HL 6671 headlight switch napa
10/09/08: fuel pump, 7-1806 napa power steering hose, 7-3364 power steering hose.
11/02/2009: new water pump, tighten steering column
02/24/2010: new stock muffler and catalytic converter
08/15/2011: Radiator, A/C service, copmpression test, motocraft ignition coil, valve stem seals, intake manifold set, exhaust pipe flange set and gasket, egr valve gasket, head bolts, carb repair.
04/03/2012: egr valve, carb choke control switch, oil pan set,
03/20/2013: magnaflow mffler and tailpipe
09/21/2013: carb mounting
08/14/2013: napa tp28sb ignition control module
09/22/2017 walmart battery
2013: duralast gold battery, battery hold down kit, cable, terminals
UNKNOWN DATE INSTALLATION STUFF
MSD pro billet ready-to-run amc v8 distributor PN: 8523
Blaster coil
Powermaster alternator
whats going on: when I bought it, it didnt run, just turn over. upon looking in the engine compartment I found the coil and dizzy were not wired in right so i replaced that. I also have replaced oil, plugs, oil filter, fuel filter, spark plug cables. The carb tsp solenoid was not hooked up so i fixed that and also replaced vac hoses and repaired a leaky evap canister. i believe it has motocraft 4300/4350? i am unsure because the stamp on the linkage side is worn off.
those fixes had gotten it to start up and to idle rough.
I next used a dial back timing light to set the initial timing to 12 degrees btc as per the sticker in the engine compartment. That enabled the engine to idle a lot smoother. I tried to drive it and here is my delimma, it dies when throttle is applied and will not go above 2000 rpm without engine noise, backfiring out of the exhaust and sometimes out of the carb. I played with the timing a bit trying 12, 14 ect all the way to 30 degrees btc for initial timing and it smooths out more the more it is advanced, but still dies under load at higher rpm. I next set my timing light to 34 and raced the engine to engage the mechanical advance and set the timing that way. that was a bit better, but it still hesitates a lot, has excess vibration and dies under load with high rpm unless you baby the throttle really slowly increasing rpm, then it still has a lot of noise.
I am unsure of what to attempt next maybe my dizzy needs work or another underlying issue is there? please help me out!
