Is there a way to adapt a dana 300 onto the factory turbo 400 trans to replace the quadratrac in a 1974 Jeep wagoneer?
turbo 400 to dana 300
77 chero DEAD.
84wag,360,tf727,???! possiblities are d300 flipped and a ford d44 hp with coils
Likely easier and cheaper to go with a NP241C, gives you the same function, was used in 3/4 trucks (though a D-300
seems pretty stout)
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
There is no "bolt in" swap for the QT, it has a unique bolt pattern and tranny output shaft.
To swap the QT out, you have to completely take apart the transmission to get to the output shaft, so you will most likely have to have professional shop take care of that part.1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
Originally posted by jeepinjohnIs the np 241c a bolt in?
Mike D.Last edited by mdill; 11-13-2010, 08:07 PM.-----------------------------------------
