Leaf Springs
  • pnlombardi
    • Aug 18, 2015
    • 9
    Leaf Springs
    Greetings from South Florida. I am in the process of doing pretty much a complete restoration on my '89 GW.
    It has high mileage on it and as such my springs were worn out. I ordered a set of 4 from Team Grand Wagoneer which indicates that they are the "stock height" however after installation they are anything but stock height.
    FRONT LEAF SPRING PART# J5362950
    REAR LEAF SPRING PART # J5362956
    Maybe I should take some pictures and include them in this post but before doing so, i wanted to see if anyone has a suggestion of what i may have missed.
    My intent was not to lift the suspension but to keep it stock.
    Any thoughts? Many thanks!!
    Peter
  • joe
    • Apr 28, 2000
    • 22392
    What's the issue, sitting lower or higher than expected? You can bet either way they'll still settle a bit more.
    The factory TSM has ride height specs. It'll include overall height, rear cargo deck height, drivers sill plate/step height etc. Assuming you have stock size tires, those would be the areas to measure.
    • pnlombardi
      • Aug 18, 2015
      • 9
      Joe,
      Thanks for the reply and sorry for not being more clear.
      The issue is that the car is clearly sitting hire than the stock height.
      What i failed to also mention is that I also purchased this body mount kit from TGW as well. it doesnt say in the description that the kit will raise the height but perhaps it did.
      We are the Largest Full Size Jeep Parts Seller in the World, Specialize in Grand Wagoneer & Full Size Cherokee! We ship Worldwide!
      I was primarily trying to determine if anyone else had ever installed the leafs I mentioned in my last post.
      THanks again!
      Peter
      • joe
        • Apr 28, 2000
        • 22392
        Curious, did you crank the spring packs down tight w/o the car weight on the springs..not a good thing. If so loosen the spring bolts while on the ground, then re-torque the bolts to spec. Then go take a spirited ride on a crap rough dirt road and hope things settle in.
        • rang-a-stang
          • Oct 31, 2016
          • 5504
          Exactly! I did that when I replaced my springs a couple months ago, too (cranked them when jacked rather than when on the ground).
          Also, know that the springs will settle a little over the next month or two (again, mine did, so I assume yours will too). I ordered Crown replacement springs but I don't remember the part number.
          Chuck McTruck 71 J4000
          (Chuck McTruck Build Thread)
          00 Baby Cherokee
          • pnlombardi
            • Aug 18, 2015
            • 9
            I didn't install the springs so I will go back to the place that did them. I'm sure that's the issue.
            I can't thank you guys enough!!
            Happy Thanksgiving!
            PL
            • pnlombardi
              • Aug 18, 2015
              • 9
              Springs
              Hey Joe,
              Hope you are well. I have yet to have the mechanic loosen the center bolts of the springs while on the ground.
              Curious to know how that would affect the ride height of them. I'm sure the physics of it will make sense when you explain it.
              Have a great holiday!!
              PL
              • gjeep79
                • Jul 10, 2017
                • 10
                Leaf springs
                Hi Peter, I was wondering how you like the leaf springs from Team Wagoneer? I was thinking about purchasing. Also do you happen to know the brand it doesn't say on their website. Any input would be great. Thanks.
                • joe
                  • Apr 28, 2000
                  • 22392
                  Originally posted by pnlombardi
                  Hey Joe,
                  PL
                  All is good here. Thanks. Don't know your reference to "center bolts" What I referred to previously were the eye bolts at the spring ends. Car weight will compress the springs some, then tighten them.
