Old 09-25-2022, 01:52 PM
djmac's Avatar
djmac djmac is offline
New Fuel Cell Sending Unit
I have an aftermarket gauge in my 82 jeep j10 that has dip switch setting to compensate for various sending units. My switch is set to 0-90 (matches my RCI Fuel Cell) and it works fine when bench tested with the sending unit out of the tank and grounded with a jumper. When I move the float the gauge responds appropriately. When I install the sending unit in the cell there is no response. The gauge is at 00. The tank has continuity to ground without an additional ground being attached but either way with a ground attached or not the gauge is at 00. Any ideas?
Dan McNeil
82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
Old 09-28-2022, 09:16 AM
Dan McNeil
Sounds like the sending unit is not getting a good ground when installed?
1967 Wag Fuel Sending Unit Need!!! mtjeep General FSJ Tech 1 10-13-2011 09:41 PM
Electric Fuel Pump Installation w/ relay leostevo General FSJ Tech 0 03-21-2011 06:07 PM
Another fuel sending unit question va1968sh General FSJ Tech 8 01-12-2007 01:05 PM
Help / Vapor Lock Issue key General FSJ Tech 9 04-09-2004 10:54 AM
OHM rating for 1981 Jeep J10 360 2bbl fuel tank sending unit to guage badaboom General FSJ Tech 11 06-20-2002 04:47 PM
