custom transfer case mount needed
  • wiley-moeracing
    • Feb 15, 2010
    • 1430
    Need a custom transfer case mount for turbo 400 with 32 chevy spline, 4x4 shaft to a early dodge 241 transfer case. I found a guy on pirate 4x4 website that did make these but I can not get a hold of him, so is someone making these anywhere else? It was a weld together kit. Or does someone have a way of contacting him? Mike at trail tech fab. com
  • Cliff
    • Mar 30, 2002
    • 864
    If you can't find the item, try a local welding shop. I once had a welder that did all sorts of custom stuff for me, often at a fraction of the price. And one of those projects was a crossmember for a drag racing AMC Spirit.
    Cliff Danley
    1977 Cherokee S
    • wiley-moeracing
      • Feb 15, 2010
      • 1430
      Thanks, its a little frustrating as this guy has what I need and have been looking for but must be out of business? his prices were good and his products looked good. I think I will print out the pics and take them to a machine shop and see if they can duplicate the set up.
      • 77Deepj20
        • Jan 24, 2016
        • 109
        I've found most custom4x4 Fab shops are not in buisness long.
        What exactly are you looking for? Just a basic adapter to mount the t case to the trans or something more complex? How are you dealing with the difference in spline count? Which th400 4x4 shaft do you have? There are quite a few different lengths.
        1977 j20. Dana 60's, 4:10's Chrysler 360/np435/NWF blackbox/np203
        Hummer military 24 bolt wheels and 37" mt/r's.
        • wiley-moeracing
          • Feb 15, 2010
          • 1430
          The adapter I am looking for is the 2 1/2 inch wide version for the 32 spline turbo 400 output, similar to the factory set up for the 241 or 208. I rebuilt the dodge 241 I have now but the mounting bolt pattern is different from the gm version but all else is the same. trail tech fab had a weld together set up that can be clocked to where I need it, was a cool set up. I am stuck on my build till I get this done.
          • babywag
            • Jun 08, 2005
            • 10286
            It?s too bad Mdill didn?t start producing the one he had designed.
            AFAIK he only had the one made.
            • wiley-moeracing
              • Feb 15, 2010
              • 1430
              Agree!
