I'm thinking of contacting this seller to make an offer....
Seller states that he did an HEI conversion without changing the distro gear out and it ate the cam gear. I have a matched set from running 360 but it has a 100k miles on them. So my question is, would you trust these used gears or would you spring for the $130 dollar matched set from BullTear? Also, would you use the HEI or go back to the Motorcraft? I have the distributor, ignition module, and everything to take it back to stock. Also, what would you offer? I seen him advertise this very Waggy on the Facebook FSJ boards for $1500.00.
All opinions are appreciated!!
