Old 05-07-2003, 01:07 PM
Stuka's Avatar
Stuka Stuka is offline
Question
Ok, the filler tube and breather (they connect right next to each other) on my J10 are both cracked and have started to leak on me. I cannot find a replacement anywhere!
Has anybody had to replace these before?
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 05-07-2003, 01:34 PM
robselina robselina is offline
these are the metal ones right? what about just JB welding them? The topic came up on the e-mail list not too long ago, might want to ask there too.
Rob
Old 05-07-2003, 01:45 PM
Stuka's Avatar
nope, these are the rubber lines going from the filler spount to the tank. The a breather line that goes up into the side of the bed. If it was steel I would have JB welded away
Old 05-07-2003, 03:05 PM
Merc69's Avatar
Merc69 Merc69 is offline
I haven't looked at the J-10 but on the Wag the ends are two different diameters. I could not find any fuel rated hose that had the different sized ends. I would up with a metal splice to link the two hoses together. Definatly a PITA.
Old 05-07-2003, 03:27 PM
twisted frame twisted frame is offline
I'll put the part # of the fuel filler hose up here tomorrow. Took me a long time to find the right kind.
Mike
1973 J4000, 360 2bbl, T18, Model 20,
44, 60-2, 32x11.5x15" on 15x8" CJ wagon wheels.
Now in black primer.
Old 05-07-2003, 04:11 PM
illegalFSJ illegalFSJ is offline
The rubber fuel filler neck for pre '80 J-trucks is one of those items that is impossible to get, as far as I can tell. I was forced to buy a cracked used one because it was better than the one I had on there originally.
Oops, you have an '81. Does that still have the big (2.5 inch) filler or the smaller (1.5) inch filler? (measurements are approximate). I think the smaller ones are easier to locate. If it's not molded into a weird shape, you may be able to use stock fuel filler tubing from a parts store?
Good luck.
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 05-07-2003, 04:24 PM
Stuka's Avatar
it is the smaller tubing for sure. it has some 90 degree bends in it though. If it wasnt for these it wouldent be a big deal. But i doubt I could bend tubing of this size into and angle like that without it pinching itself.
Old 05-08-2003, 12:10 AM
Geeeep's Avatar
Geeeep Geeeep is offline
I went to an industrial hose shop and had them match up something close in fuel rated hose. The right place should even be able to put a bend in it for you.
Dave Pitts, located directly over the center of the earth!
GW - 87 GW 360/4bbl/727/208 Vinyl floor, manual windows, no woodgrain
Find someone to haul your Jeep here: YT Hauling Schedule
Old 05-08-2003, 01:27 AM
Stuka's Avatar
i would drive to drive a few hours away to have something like that done though
Old 05-08-2003, 03:59 AM
Sorry, I have the larger dia. tube.
Mike
Old 05-08-2003, 05:15 AM
momerath momerath is offline
I just spent the better part of three weeks looking for this same hose for my '73 Wag. They don't exist. I wound up buy 1-3/4" fuel-rated hose and putting hose clamps around it to keep the worst of the kinks out. Still have to go slow at the gas pump, but it beats having gas running across the parking lot...
Old 05-08-2003, 05:26 AM
The Donzi The Donzi is offline
I just replacd the fuel filler hose and had to get a rubber shop to cut me a piece with 1" ID with a coiled wire insert to prevent kinking, it worked out pretty good. Only cost 10.00 with two hose clamps.
1979 Cherokee Chief <br />360,400,1339,44,14ff,SOA,<br />Hydro assist,44044\'s, 63\" chevy rears, Dual electric fans, 35\"SX\'s on hummer rims Rhino lined interior, f/r reciever hitches, Warn 9000i<br />Edelbrock intake, truck avenger<br />Engle cam, chopped, caged
Old 05-08-2003, 01:07 PM
Stolen76 Stolen76 is offline
I got one for something, bought it as a NOS factory part. Breather is on the wrong side for me though.
http://bellsouthpwp.net/d/r/drdiesel/ebay/hose.jpg
76 Wag, 360, TH400, 3.55\'s<br />Q-Trac P/T, 16%OD, 2\" AAL<br />Uniroyal LT265/75-16\'s on 16x7\'s
Old 05-08-2003, 03:28 PM
letank's Avatar
letank letank is offline
for the 74 wag , i got the breather tank hose (like 3/4) at a truck repair plant..... and did not check if they had the larger one..... it is still holding... good San francisco foggy weather keep it all cool and soft... did i say soft
Michel
74 wag
Michel
85 Gwag, 225 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
Old 05-08-2003, 04:03 PM
Stuka's Avatar
My J10 came fromt he desert. So the steel is all great, but the rubber is all dry rotted out.
I will have to draw a diagram up of it tomorrow.
