Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 05-15-2018, 06:11 PM
TheWeekendWagon's Avatar
TheWeekendWagon TheWeekendWagon is offline
Vapor Separator
Looking for a vapor separator for my 1990 GW. I am aware that this is not "needed" but I want one. Looks like a fuel filter but it goes in-line with the vacuum line that goes from the charcoal canister to the carb. It's the piece circled on the bottom right of this photo...
And on the vacuum layout diagram you can see where it goes. It is labeled with the number 3 in this photo...
Looking for a take-off from another GW or if anyone knows of a new aftermarket replacement that works too. It's the last missing piece of my car's vacuum system!
Jeeper Level: Noob
3 Jeeps + A Datsun
2014 JKU Rubicon /// 2018 Grand Cherokee /// 1990 Grand Wagoneer
--->YouTube Channel<---
Old 05-15-2018, 07:25 PM
Bearman Bearman is offline
Fuel seperator
I bought these. They seem to be new old stock.
https://m.ebay.com/itm/LOT-OF-TWO-IN...pid=1717883723
81' Jeep J10 currently restoring piece by piece
Old 05-15-2018, 08:12 PM
Those are fuel filters. The fuel vapor separator connects to the carbon canister and the top of the fuel bowl on the carb.
2011 Nissan Pathfinder Silver Edition 4x4
2009 Mazdaspeed3 Grand Touring
1979 Jeep Cherokee Chief Wide Track, 401, Full 3" Borla exhaust, Headers, Front Shackle Reversal
Old 05-16-2018, 09:51 AM
Thank you! I really hope those end up working. Like rang-a-stang said they may be fuel filters but I am trying to figure it out for sure. They look exactly the same but what has me confused is the color and the fact that it says "Flow to Canister" on it. But then again the listing says they're fuel filters and when I search the part number limited info comes up except a thread on here that says it's a vapor separator. Then I have rang-a-stang saying they're fuel filters...I just don't know haha. Will have to continue searching for definitive info...
Jeeper Level: Noob
3 Jeeps + A Datsun
Old 05-16-2018, 10:12 AM
Mine has a side outlet, more like these:
https://www.ebay.com/itm/LOT-OF-TWO-IN-LINE-FUEL-FILTERS/252297322807?rt=nc&_trkparms=aid%3D222007%26algo%3 DSIM.MBE%26ao%3D2%26asc%3D50544%26meid%3Dff7989746 b5f4e2b8b8a0b3517b0f410%26pid%3D100005%26rk%3D1%26 rkt%3D2%26sd%3D253335632737%26itm%3D252297322807&_ trksid=p2047675.c100005.m1851
Old 05-16-2018, 11:14 AM
Those look more like what's drawn on the diagram. This is why I am hoping to find a take-off from someone else's GW that I know for sure is the right thing because from what I have read they look very similar on the outside but are very different on the inside.
Here's my next question, is there a place that might list the OEM part number for the vapor separator? Maybe we can cross reference that with the eBay ones...
Jeeper Level: Noob
3 Jeeps + A Datsun
Old 05-16-2018, 11:24 AM
Nevermind I answered my own question and found the part number. Searched that and found this thread...
http://www.ifsja.org/forums/vb/showthread.php?t=181885
Looks like it's the blue ones!
Jeeper Level: Noob
3 Jeeps + A Datsun
Old 05-16-2018, 01:22 PM
Sweet! Glad its going to work out! Sorry for the bad info.
Old 05-16-2018, 05:59 PM
nograin's Avatar
nograin nograin is offline
No its not. It says right on it: Flow to Canister
That's a correct original AMC part.
The ink stamped number is exactly the same is the one I posted:
http://www.ifsja.org/forums/vb/showp...18&postcount=6
http://www.ifsja.org/forums/vb/showp...5&postcount=23
edit: Good job - I see you already found the follow up thread where I uncovered the original from my '85.
That's a good question. The one Rang-a-stang posted a link to I'm sure is also a liquid trap (aka vapor seprator).
Take the part number for the liquid trap, ad "Chrysler" to it, and do a websearch to see if it will show up in Chryslerparts, factorychrysler parts or a similar dealer website with an on-line parts list. If so, you can see all the years it was used and any superceded numbers.
Here's one: But the application listing is a little unclear.
https://www.factorychryslerparts.com.../33001586.html
Or, see if there's a parts catalog for 1990 available on-line and down-load that. Maybe at 'Ol jeep?
Or, see if a Jeep dealer will look up the number and check if its the same as used in 1990.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 05-16-2018, 07:38 PM
I apologize if i gave any bad information. They were what I orderd for my j10. I I recall them saying to canister on them also.
Iím curious what do you call the light blue items with the clip on it located middle left in the picture. I know it goes into the breather housing and vacum lines connect to it. The one on my breather has a broken nipple and would like to fnd a good one.
Old 05-16-2018, 10:00 PM
no, you were right bearman,i was the wrong one.
Old 05-19-2018, 10:05 PM
nograin's Avatar
if you edit your post we wont get confused
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 05-19-2018, 10:09 PM
nograin's Avatar
You mean in the very first picture in the thread?
Those are the air temperature switches for the EGR. They go in the aircleaner housing and the nipples stick out the back.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 05-20-2018, 09:03 AM
Yeah, the ones in the first picture. Thanks for the response. Iíll look for a good used one now that I know what they are.
