Instead of tracking down various vacuum leaks, I hooked up a vacuum pump directly to the shift motor which is supposed to lock the front axle of my 83 Cherokee (with swapped 208, btw). With the vehicle on 4 jackstands I tried applying up to 20 units of vacuum (and rotating wheels) with no lock of the axles. My understanding is:
-After removing the harness from the shift motor, there are 3 vacuum connections.
-Vacuum to the top connection keeps the axle unlocked (2wd)
-Vacuum to the second locks the axle for 4wd
-Vacuum FROM the third connection signals the T-Case to engage (but that NP229 has been removed and replaced with a 208 which does not require vacuum control, only the lever) after hubs/axle lock.
Correct me if I'm wrong about the above.
I can't seem to engage the front axle no matter what I do. My next step would be to open the peephole (fill hole) of the axle and see if I can spy the action of the shift motor, to see if it moves at all. I'm thinking I should be able to remove this fill-hole nut (with 1" square tool?) and stick my finger in there and feel around to see if that rod is moving down from the shift motor trying to engage the clip.
I've never messed with the axle before, but there's no way of removing/testing the shift motor without accessing the innards of the front axle.
Thanks for your input.
