what seats did it for you?
replacement seats....anybody?
www.j10mike.com
Tags: None
I got a set of those BestTop seats (made for CJ's/Wranglers). They are great in the Wag. A million times better than the crappy seats FSJ's came with. Plus, with some simple fabrication, you can make them work with the factory power seats.83 Wagoneer Limited (R.I.P)
360, TF727, NP228
SOA, 35's, WT Axles, 4.10 gears, Detroit Locker
dome, bentpushrod,
do your seats sit up any higher than the stock seats?
mikewww.j10mike.com
Originally posted by J10Mike:
dome, bentpushrod,
mike
However, I believe that the seats will bolt directly up to the manual seat frames, in which case, I do not see any reason why they should sit higher than the stock seats.83 Wagoneer Limited (R.I.P)
360, TF727, NP228
Great topic J10Mike.
I put 85 GW power seats into the 70 wag, a big step up from the original bench seat but they provide very little lumbar support and were very jaring at Ouray and the 1,100 there and back. I would like to keep the power seat brackets and find something more accomodating for my spine.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
These in the lil jeep are Ford Explorer leather. All power and really comfortable. Plus they are easy to find...Can you say "rollover?"
I will check and see if the brackets are stock or custom.
Cary<br />The bald guy<br />65 Waggy and lots of other projects waiting in the wings
cary,
it seems that i read somewhere in another post some time back that someone stated that explorer/mountaineer seats were an excellant replacement seat for fsj. i just need to see if the brackets need to be modified or if the seats will be somewhat raised height wise over the stock seats.
mikewww.j10mike.com
The seats sit a little higher in the little jeep. The shifter knob needs about a 1" extension, but the 400way power seats make it ok. Not near as annoying as the game of twister you have to play to use the emergency brake with that D#$^ full roll cage.
I bet they would look really nice in a Fullsize, but my waggy is no where near ready to worry about the insides yet.
CaryCary<br />The bald guy<br />65 Waggy and lots of other projects waiting in the wings
cary,
do the seats push forward? like if you were to want to put something behind the seat.www.j10mike.com
I would think that since they make a 2 door Explorer that they would, I will check next time I drive the Jeep. It is our Shop Toy and I usually get it when I need it or it needs something done to it.Cary<br />The bald guy<br />65 Waggy and lots of other projects waiting in the wings
