Originally posted by DarkMonohue
AMC360 Budget Build w/343 Pistons
The Squeaky Wheel gets replaced in my world
No problem. It would be tough to get an objective sample with such different usage.'85 J20 Old Man Truck, bought @ 65K miles - not great, but better than walking.
Originally posted by babywagWhat style is the stock chain in say '86-up motors.
Every one I've had apart was stretched a bunch.The Squeaky Wheel gets replaced in my world
Originally posted by babywagI believe they stopped using nylon gears in 80's?
Last 2 I had apart had OE part#'s and were not nylon.
('86 & '88)
Yes, It appears they did change. Current (1991) Numbers are:
J3234234 Cam Sprocket .50” Wide Steel Gear
J3234235 Crank Sprocket
J3234433 Chain
J3223199 Crank Sprocket .62” Wide
J3197138 Cam Sprocket is .62” Wide.
J3185270 is the oldest Chain no idea
J8134343 is .62” Wide (31834343) Nylon Gear
Last edited by SC/397; 04-13-2016, 07:55 AM.The Squeaky Wheel gets replaced in my world
Looking good. Is that the real-deal AMC paint you were gauging support for in another thread?'85 J20 Old Man Truck, bought @ 65K miles - not great, but better than walking.
Originally posted by DarkMonohueLooking good. Is that the real-deal AMC paint you were gauging support for in another thread?
I traded emails with Amark, the vendor who was supplying the Late '73-'83 AMC Engine color and he is re-stocking. So, I refer people to go to him now.
Last edited by SC/397; 04-28-2016, 11:27 AM.The Squeaky Wheel gets replaced in my world
Thanks. I have had good results with a lot of Dupli-Color products in the past. That is probably close enough for a beater pickup. Either way, it will be interesting to compare it to the correct color once you get it applied.'85 J20 Old Man Truck, bought @ 65K miles - not great, but better than walking.
I have a mechanic friend that has been telling me I would be much happier with my engine if I got the compression up. When I showed him your your write up he was really braggin on it. I plan to do the piston swap on my 360 like yours. Thanks for taking the time to do a write up and making it simple so people like me understand what's going on.81' Jeep J10 currently restoring piece by piece
