Old 07-28-2012, 08:08 PM
Etcetera Etcetera is offline
Anyone using rear springs in front?
I am going SOA in the front of my 75 waggy, swapping in a GM 3/4 ton axle. I understand the stock front springs don't like running spring over. Anyone using the rear springs in front? I'm upgrading front and rear hangers, so it wouldn't be a big deal to move them a bit to accommodate the longer length. I have it mocked up with the stock front springs and they already look unhappy, lol.
Eric
La Habra, CA
75 Wagoneer
Old 07-28-2012, 09:07 PM
Stuka's Avatar
Stuka Stuka is offline
Where did you hear the front springs don't like to be in an SOA config? If they are in very bad shape, maybe. But if in good shape they should be fine. You will get more axle wrap in an SOA config, but longer springs would actually make that worse.
As for rear springs up front, it depends on what year springs. 76+ used 57 inch springs, and you could not easily use these up front, it would push your axle back. Your '75 uses shorter 52" springs, which could be made to work. Although the spring rates are different.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 07-28-2012, 09:12 PM
Almost every SOA thread on this site says the stock front springs are no good SOA. I guess I can run them and see, won't really be any extra work to try them.
Both front and rear are in good shape I guess. The rears are really good because it had an add a leaf helper since new so they didn't sag. I am putting 63's in the rear with a 14 bolt. Going to run 35's.
As soon as I get some u bolts for the front I can set it down and figure out where the rear needs to be.
Eric
La Habra, CA
75 Wagoneer
Old 07-28-2012, 09:14 PM
Just to clarify, I'm stretching the wheel base in front and rear. If I use the stock fronts they will be reversed giving me about 2" or so. If I run the stock rears I will move the rear mount back about an inch and mount the front shackle hangers just past the end of the frame on the bumper.
Eric
La Habra, CA
75 Wagoneer
Old 07-28-2012, 10:29 PM
Originally Posted by Etcetera
Almost every SOA thread on this site says the stock front springs are no good SOA...
Actually the posts say they were not designed for an SOA application, which is true. If they are in poor condition to start with when doing an SOA, they do no last long (how long depends on wheelin' style/choice).
Inserting a secondary main spring helps, as do aftermarket spring applications. Be careful and take good measurements, you can only move the front axle forward so far before creating steering issues.
Old 07-28-2012, 11:56 PM
Another option is to buy a set of Chevy front springs--same length but with a centered pin. Im using a set (spring under) on my J20 with a shackle reversal. The Chevy springs are made for spring over and are cheaper than FSJ springs.
Old 07-29-2012, 03:05 AM
blazer3664's Avatar
blazer3664 blazer3664 is offline
What years?? I am guessing third Gen ('73-'87) correct?
Jim
1978 Cherokee chief AKA = Butt Ugly
Current status = BACK under construction
modified body w/TJ flares
AMC 360, junkyard TBI, 4L80e
NWF doubler w/
upside down 203
SOA D60/14B-FF
custom shackle flip w/F150 springs
H1 wheels + (for now) tires
-----Coming Soon-----
snorkels,
home brew OBA+OBW
Old 07-29-2012, 05:03 AM
Jim
Yep--the center pin moves the axle back 1" on the FSR where it needs to be.
Anyone moved their front axle forward by reversing springs? Grantshire Off-Road FSJ Tech 43 04-25-2010 06:44 PM
Im Going to it--57" rear springs mounted to the front rocklaurence General FSJ Tech 13 11-30-2009 07:11 AM
Rear springs for a front shackle reversal-has it been done? rocklaurence General FSJ Tech 6 06-09-2009 07:25 AM
Rear Shackle Pics Needed - Shackles bind on 3" Rusty's 'Special' Rear Springs Greg Taylor General FSJ Tech 6 09-25-2007 10:10 AM
