Old 09-04-2012, 05:45 PM
temps425's Avatar
temps425 temps425 is offline
New A/C Compressor Swap - eBay Deals!
Hey, I was looking on eBay and saw these four season A/C Compressors..
http://www.ebay.com/itm/FOUR-SEASONS...#ht_706wt_1398
Has anyone swapped one of these in with much success? Seems to be for the 4.2 but I was wondering if it could be easily adapted to fit a 5.9, maybe with some brackets?
This one appears to be a direct fit and should bolt on but is nearly 3x the price....still looks like a good deal.
http://www.ebay.com/itm/GLOBAL-PARTS...ht_1631wt_1397
Old 09-04-2012, 05:53 PM
serehill serehill is offline
Gone,Never Forgotten.
YUP
You can fiond everything to do it on Ebay.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 09-05-2012, 09:51 AM
Walt's Avatar
Walt Walt is offline
The 6 cyl and 8 cyl compressors have the same mountings and are physically interchangeable for later model wags having the sanden compressor.
The difference is number of pistons and displacement (ie- cooling capacity).
Compressor for 6 cyl applications (SD507) is five piston unit with 7 ci displacement. 8-cyl applications (SD709) is seven piston with 9 ci displacement.
http://www.sanden.com/originals/imag...uide_Rev.2.pdf
That york in your 2nd link is NOT a direct fit replacement if your wag is a later model already having the sanden.
90 G Wag.- New Motor/Trans/TC...Soon to have TBI!: CS-144 Alt; Parallel Flow A/C Condenser; Read this BEFORE you install an HEI ignition module!
Old 09-05-2012, 12:41 PM
cma's Avatar
cma cma is offline
and: the 507 / 709 are R12 compatible also the York one.
i would not buy a reman compressor, only new ones and no chinese only original Japan! the manufacturing quality is too bad (they use often scraped compressors for rebuilt).
Markus!
Picture story:
A/C blower is back GED General FSJ Tech 0 07-05-2004 04:16 PM
A/C retrofit. Puvong General FSJ Tech 2 05-29-2001 01:16 PM
A/C BLUES - PLEASE HELP ! ! Jordo Other 16 08-06-2000 05:32 PM
