81 j10 727 with low range. Have an output seal leaking. Trying to order parts, I'm a couple states away from it so can can't just crawl under it. What TC should be under there?
Hate to ask..
Hate to ask..
Wannabe Fabricator
Grumpy on a good day.
What I'm working on: http://www.ifsja.org/forums/vb/showt...50#post1503850Tags: None
Most likely a NP208-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Thanks manWannabe Fabricator
It could also be a NP219. Can you share a picture of the flag shifter handle? It will have the shift pattern on it.Flint
Originally posted by fulsizjeepIt could also be a NP219. Can you share a picture of the flag shifter handle? It will have the shift pattern on it.
-Jonny B.
Wannabe Fabricator
Agreed, a part time setup from that era should have an NP208 behind a 727. My '85 J20 does and the parts catalog indicates the same thing for your '81 J10.
Jeep part numbers for output shaft seals (where the driveshaft yokes exit the transfer case) are 83504434 for the front and 83502508 for the rear. Those cross-reference at RockAuto to SKF numbers 18771 front and 18662 (or Timken/National 3946) rear.'85 J20 Old Man Truck, bought @ 65K miles - not great, but better than walking.
Thank you gents. I'm still pretty far away from it. I'll order those seals and hopefully they are waiting for me when I get some home time.Wannabe Fabricator
