Rear Discs
  • Marc
    • Apr 16, 2000
    • 181
    Rear Discs
    Has anyone seen/done any sort of rear drum to disc swap with any success? I know Ch--- guys can rob parts for a rear conversion from caddies or something like that but what about a cheap swap for Dana 44s or 60s?
  • fulsizjeep
    • Aug 21, 2002
    • 22496
    One of our friend's has a CJ5 with Wagoneer axels on it (6 bolt). He used the front disks and calipers from another Wag front end to fab rear discs on the CJ that work pretty well...
    • Damage, Inc.
      • Jul 08, 2002
      • 1442
      I'd be interested in this, too. Anyone have good info on it?
      74 Cherokee
      • Rick78J10
        • Apr 20, 2001
        • 501
        How about discs for the model 20?
        • tc
          • Jan 08, 2002
          • 361
          Blt2crl did the convertion for about $200. New rotors, calipers, ect. If you do a search I think he explains it some where.
          "I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Frank Sinatra
          • johnypreflt
            • Mar 18, 2002
            • 280
            for the model 20 I was given the following info:
            You would use the 2460 conversion. It is $249.95 for brackets, rotors
            and
            bolts.
            We also have calipers and flex lines. If yours is the narrow track you
            can't
            use
            the parking brake calipers because the lever is too close to the frame.
            for
            more
            info check our web site tsmmfg.com Skip
            BLUE BEAST,1980 J-10 (FOR SALE)
            CHEVY 350,th350,33" SIDEWINDERS
            PICS http://www.fsjworld.com/prefltspage/
            [email protected]
            • BLTUPFSJ-J10
              • Nov 06, 2002
              • 11
              You can find a good conversion from TSJ in back of most 4X4 mags I did myself 85 j10 Dana 44 kit cost about 200 simple install maybe took an 1hour total, had the big items off already,all you need will be simple shop tool's, Oh and I bought my calipers from the auto parts store, save's you a little, and if you need emergency brake , get ready to dig deeper in the pocket, so I opted for a line lock device saved me about 400.00
              • ozarkjeep
                • Apr 20, 2001
                • 7
                go here
                A&A Manufacturing has been the leading manufacturer of custom chassis components since 1966. Made in the USA
                get 2 part # 049-a
                get 2 front 80s FSJ calipers, the slider bolts, and some rotors from a 97 Chevy tahoe.
                No E brake ( the caddy E brakes dont work well anyway)
                under $200, load the calipers, bolt them to the brackets, and apply air pressure to teh caliper to clamp it square on the rotor and then you can tack weld the bracket in the proper place on the axle tube, or you can spend $100 more and get some bolt on brackets from various sources, or make your own, the AA brackets are $6.50 each
                youll need to cut the center section out of the brake backing plate, and use it still as a bearing retainer, housing cap.
                Too small to be seen and too big to control, and treated like a walking bomb.....
                • Sitting Bull
                  • Sep 18, 2000
                  • 3471
                  A good thing to keep in mind though...if you have no e-brake, you will be unable to ride on almost all sponsored trails, or private trails with inspections. I believe a working e-brake was a requirement of our gathering at Ouray as well.
                  Brad Reardon<br />1977ish Cherokee Chief.
                  • blt2krl
                    • Apr 03, 2001
                    • 3730
                    Good point Sitting Bull. I think though a line lock is a way around that not sure though.
                    Paul Hartman
                    79 waggoneer
                    AMC360/TH-400/203/205
                    DANA 60/14 BOLT 5.13'S AND DETROITS
                    39.5 IROKS C.B.I OFF ROAD TUBING GALORE
                    www.cbioffroadfab.com
                    WWW.PLANET4X4.NET
