I might have a good deal on a NV242HD, s0 anyone know how difficult it is to get an adapter plate fabbed up to bolt to the 727 torque-Flite Auto Transmission?
My NP229 is OK, and the Viscous Coupler is fine in it, however that vacuum stuff has been eating at me for some time now, not to mention all that slippage.
I am gathering info on swapping in the NV242HD in place of the NP229, that is currently behind my Chrysler Torque-Flite 727 Transmission.
The NV242 has a 2.72:1 low range and has all of the possible mode ranges including the ability to lock the planetary open center differential if desired.
When the differential is locked so that both the front and rear driveshafts operate in unison (no slippage) it is referred to a "Part-Time" because this mode should not be used on the street, due to lack of tire slippage and therefore binding and torqueing of U-Joints and axle shafts.... therefore the "Part-Time" moniker.
2WD (Sends all power to rear wheels)
4WD High, full-time (Sends power to all wheels)
4WD High, part-time (Locks both front and rear driveshafts for increased traction)
NEUTRAL (Allows vehicle to be towed)
4WD Low, part-time (Doubles the transfer case gear ration for severe road conditions and low-speed pulling power)
I think that these were used in Dodge's (Dakota's and Durango's) and in some Jeeps (WJ's?).
Guess I will have to buy the service manual:
NP229/242 Transfer Case ATSG Technical Rebuild Manual
NV242
NP229
NV242
NP229
