Old 04-10-2007, 10:35 AM
86comanche 86comanche is offline
front axle swap question
I ma looking for a dana 44 or 60 front axle for the front of my 69 j-3000. The rear axle is a dana 60, with 5 on 5.5 lug pattern. What donor truck can i get the front axle from with disc and the same bolt pattern?
Old 04-10-2007, 12:58 PM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
a front d60 will be 8 lug. the pre 80 ford half ton front d44s have the same 5x5.5 lug pattern to match the rear. but, i'm pretty sure the spring perches would have to be moved.
www.j10mike.com
Old 04-10-2007, 01:37 PM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
Those wouldn't work either- the ferds have a drivers drop whereas he needs a pax drop. An early 80s dodge truck dana 44 will work- member Josh D did a swap to his 71 J2000.
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
Old 04-10-2007, 02:12 PM
J10Mike's Avatar
Doh...I can't believe I missed that. I think I'll get a cup of coffee now.
www.j10mike.com
Old 04-10-2007, 02:24 PM
goldhammer's Avatar
Awww shucks. just cause you got the same backwards front end I do don't mean a thing
Art
ASE Master Collision Tech
Old 04-10-2007, 02:36 PM
I got the Willys....
I'd say that you would be best off with a GM D44 or 10b converted to 5 lug using Ford parts, or a Dodge D44 which has the same 5 on 5.5" bolt pattern.
For a D60, I know you can get 6 lug hubs, maybe you can get 5 lug hubs as well. Probably not worth spending that much money though.
1971 Gladiator
