Old 02-16-2007, 01:43 PM
JeepNOFEAR's Avatar
JeepNOFEAR JeepNOFEAR is offline
The most annoying thing to work on, on your jeep
I had to cut the ends off on the studs that hold the exhaust and manifolds together. Getting those studs out of the exhaust is the most annoying thing I've ever had to do on any of my Jeeps.
I was able to get the 1st one I touched out with vise grips, hurray this will be easy. The second one would not move. I went and got my torch tanks filled. I heated it up and I could bearly move it. So I welded a nut on the end of it. Success!!!. Now onto the other side of the motor. Tried all the steps and they both end up breaking off in the manifold. I had to walk away from the Jeep after that. Time to bust out the drill.
What kind of problems have yall all run into?
76 Cherokee Camo(Parts)
76 Cherokee Camo 401/TH400/Dana300/HD44/14bolt/36s
77 Cherokee blue 360/T18/D20/33s
1969 AMC Javelin SST 390
1968 AMC Javelin SST 290 (Parts)
Old 02-16-2007, 01:56 PM
Headhoncho's Avatar
One time, when I was removing the aircleaner, I bent one of my fingernails back, and it like hurt like alot.
I think the exhaust manifold studs are one of the biggest PIA's there is. I feel for you on that one. Next is working on old Datsun Z motors when you snap a bolt off in the aluminum head. They're a blast to drill out from aluminum. At least it's cheap crap japanese steel.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 02-16-2007, 01:58 PM
chrisnsarah's Avatar
I don't know where to start, so I'll start with a few:
The upper starter bolt on a 360.
The backlight for the heater control on a Kaiser era truck.
The sparkplugs behind the heater box on a V8.
Valve adjustment on a Tornado 230 (with the engine running).
And of course, Torx bolts-any and all of them, especially seatbelts.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 02-16-2007, 01:59 PM
Headhoncho's Avatar
One more is all the stupid torx head bolts from the seat belts, door hinges, to the u-joint straps. An impact screwdriver definitely comes in handy.
JR
Old 02-16-2007, 02:05 PM
Cherokee01478's Avatar
Cherokee01478 Cherokee01478 is offline
Same with me - I mentioned it on a thread a while back.
If nature abhors a vacuum, how does a vacuum feel about nature?
1979 Jeep Cherokee Chief Widetrack, 5.9l (360cu) with a Holley 600 carb.
Old 02-16-2007, 02:08 PM
elskeptico's Avatar
elskeptico elskeptico is offline
I've been lucky with my exhaust manifolds.
The most annoying thing for me so far has been the electric rear window, when it sometimes works, sometimes doesn't, sometimes stops halfway down or up. If it's not working you need to crawl inside over the seats to pull off that panel then jump the wires to a 12v source, yada yada yada. Gets real fun in 100 degree weather.
The manifolds sound worse though.
1979 Cherokee Chief S, 360, TFI, Part-time conversion, rust
If you go lookin' for rust, you'll find it.
Old 02-16-2007, 02:27 PM
goldhammer's Avatar
Hope you use anti-sieze putting them back in and on the nuts holding it together.
Art
ASE Master Collision Tech
Old 02-16-2007, 03:06 PM
CustomWag's Avatar
CustomWag CustomWag is offline
Originally Posted by chrisnsarah
...The sparkplugs behind the heater box on a V8....
#6 & #8 are a LOT easier to get to from under the rig
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 02-16-2007, 03:19 PM
crispyboy's Avatar
crispyboy crispyboy is offline
definitely spark plugs and exhaust manifold bolts
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 02-16-2007, 03:32 PM
JeepNOFEAR's Avatar
PART 2
Well I have extra 2 sets of manifolds lieing in my shed and extra gaskets so I decided I'd use one of them on the passenger side. So I start unscrewing the back emissions bolt thing on the manifold and it breaks, doesn't really matter so I'm fine. I loosen all of the manifold bolts, I thought. I started at the back and took out the first 2. Then the third one breaks. So now I have a stud in the head to take out, HURRAY!!! I guess atleast I'm down to just one stud.
Should I heat it up or not and then try to take it out with vise grips?
Also do I have to go back and use hollow bolts?
Old 02-16-2007, 03:40 PM
chr1s's Avatar
chr1s chr1s is offline
Beach Bum - moderator
Originally Posted by elskeptico
...the electric rear window
x2 -I loathe that $@*$@%#$)%*^! thing
87 Grand Wagoneer -(UNDER CONSTRUCTION)- "TROLL SMASHER II"
88 Grand Wagoneer- GONE
"many miles away, there's a shadow on the door, of a cottage on the shore, of a dark Scottish lake......many miles away..."
________________________________________
*** Current Jeep Status ***
JEEP IS : . . .
Old 02-16-2007, 03:49 PM
orangecherokee's Avatar
removing and installing the transmission
i could definitely live with paying someone else to do that.
Old 02-16-2007, 04:00 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
For me the most annoying thing on V-8's besides spark plugs is changing out the mechanical fuel pump...Then after it's all said & done you take a look at the fuel pump on a 258
'65 J2000
Old 02-16-2007, 04:33 PM
Probably true. I can get to the #6 & 8 plugs with a regular socket handle from above. The problem is I risk cutting my hand on the metal heater box when the plugs break free. Gloves help, but it's still tight.
Threading them back in is almost as bad since it's hard to see .
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 02-16-2007, 04:56 PM
BRUTUS's Avatar
BRUTUS BRUTUS is offline
Upper starter bolt I despise. Especially since i stripped out the threads in the bell housing so I just went to a 1/4-20 with a nylock nut. It is ALL but impossible to hold two wrenches on there and tighten it down. Good thing I have headers because there is just enough room to get at them through the fenderwell and headers.
My truck was made before torx head bolts... NEENER NEENER NEENER!
Old 02-16-2007, 05:05 PM
DanHS's Avatar
DanHS DanHS is offline
Anything underneath that's rusty, sharp, and filthy. I think the two things that really gave me a headache were trying to remove the y-pipe (which ended in having to cut it, then have it rewelded with new nuts welded to the studs), and replaceing the selector shaft seal on the trans, that was awful too.
My FSJ pics
FSJ Grille Identification
Old 02-16-2007, 05:18 PM
Changing a mechanical fuel pump at night, in the dark, in some strangers driveway who cant speak any english, w/an adjustable wrench, metric sockets, "99 cent special" ratchet, and a pocket screw driver...All to try and get to my night class on time but only in vain.
Ask me how I know...
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 02-16-2007, 05:33 PM
BenE's Avatar
BenE BenE is offline
New to FSJs, I can’t complain yet (the 360 out and in went smoothly), but wrenching on the small ones my least favorite job is GREASING. The more you improve your rig it seems like the number of zerks goes up exponentially.
Hate stupid TORX too.
Ben
1988 Jeep Grand Wagoneer (rebuilt)
2003 Jeep Wrangler Rubicon (built)
1998 Dodge Ram 3500 diesel dually 4x4 (tow rig)
Old 02-16-2007, 05:39 PM
My '79 is the only one with Torx. after several days of trying to remove the seatbelt bolts with pb blaster, a torch, and breaking 5 torx sockets, the Sears clerk almost knew me on a first name basis .
I might add to the list: Pulling the hub on an earlier 2-piece tapered rear axle.
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 02-16-2007, 06:01 PM
Rainman's Avatar
Rainman Rainman is offline
Anything that puts me in harms way of the hood latch. Since I'm 6-4 and my rig has no lift, just about anything on the driver's side of the engine qualifies.
John
'87 Grand Wagoneer
4" lift, 31s, 5.2L Magnum
Current Jeep status: Operational...mostly
