Old 02-24-2010, 12:04 PM
ksq2's Avatar
ksq2 ksq2 is offline
Flat top knuckles
We're building a 78 narrow track, cherokee. It has the stock D44 in the front. What vehicles should I be looking for in the salvage yard to find the correct driver and passenger side flat top knuckles to be drilled and tapped? The archives have been extremely helpful, I just couldn't find a list of vehicles to be looking for, perhaps I didn't look close enough? Thanks!
Old 02-24-2010, 12:21 PM
orangebike's Avatar
orangebike orangebike is offline
earlier cherokees like 74 75 has them....also mid 70s chevys
81 chief-straight six auto soa and 3 inch body lift 3/4 ton running gear...37 boggers...ready for 39s....Wheeler
74 401 t18 lifted 6" on 33s for now..soon to be firewood/tow rig
73 j4000 -360-th400 d20 on 33s....now the farm rig
Couple parts jeeps
66 chevelle ss-396
66 chevelle clone 396
Stuff for free.....is worth saving up for
Old 02-24-2010, 01:48 PM
ClovisMan's Avatar
ClovisMan ClovisMan is offline
Weird, my 78 had flattop knuckles. I swapped them to my 88.
1988 Grand Wagoneer currently in pieces across the shop.
Old 02-24-2010, 02:02 PM
Pavementsux91XJ Pavementsux91XJ is offline
70's and 80's anything with a front 44, so half ton and 3/4 ton chevy ford and dodge. I know most Fords and Chevys will have the driver side drilled and tapped. I've never seen (doesn't mean their not out there) a stock junkyard axle with a tapped passenger side. It's not hard to drill and tap them yourself, just get a good cobalt drill bit and make sure you center punch it and drill a pilot hole first. I did it on my XJ with the knuckle on the axle with no problems
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
Old 02-24-2010, 08:54 PM
J20 project's Avatar
Umm..your 78 doesn't have them??
J20
BP Drivetrain...........
775-537-7918
Old 02-24-2010, 08:59 PM
orangebike's Avatar
my 77 and 78 didnt have them....seen them on a 75 before
Couple parts jeeps
66 chevelle ss-396
Old 02-24-2010, 09:07 PM
I knew 80 and up changed.. I have a 78 wt front end out back of the house w/ them.
J20
775-537-7918
Old 02-24-2010, 10:46 PM
EnigmaticEngineer EnigmaticEngineer is offline
interesting
My 1977 Parts waggy has flat tops on it...both sides, neither milled/drilled. They are getting high steer'd and going under my 69.
Nathan.
1969 Jeep Wagoneer
Currently Sitting and Possibly for sale.
Photobucket
http://s196.photobucket.com/albums/a...ep%20Wagoneer/
Facebook: EnigmaticEngineer
Gmail: EnigmaticEngineer
Old 02-24-2010, 11:07 PM
Dome's Avatar
Dome Dome is offline
Everything you want to know and more about D44 flat top knuckles.
http://77cj.littlekeylime.com/flatop_knucles.html
83 Wagoneer Limited (R.I.P)
360, TF727, NP228
SOA, 35's, WT Axles, 4.10 gears, Detroit Locker
Old 02-25-2010, 04:43 AM
78 is a FSJ change over year where some have flat tops and some don't. 74-77 FSJs with disk brakes will have what you are looking for. For the other brands, the web site Dome listed is probably be a good source of info.
Old 02-25-2010, 07:07 AM
Green Giant's Avatar
Green Giant Green Giant is offline
What he said.
Both of the 77s I have owned had flat tops, but neither of 78s have had them.
Todd Moon
78 Cherokee Chief
78 Chief
66 J-3600
69 J-3500
67 CJ-5
67 J-100 w/BARN DOORS
48 CJ2-A
Proud member of Carolina Full Size Jeep Club
cfsjc.com
No part of this post, written or pictured, may be re-used by any individual or organization or publication without my express written permission.
(Thanks, Flint!)
Old 02-25-2010, 03:58 PM
ksq2's Avatar
Thanks for the information. The article Dome linked was very helpful. One thing in the article confused me, it said the American manufactured vehicles only used two different type of flat top knuckles and Jeep used only one. Would both types work? And, sorry if this is a dumb question, what does bolt pattern have to do with it?
My father-in-law has a '74 Scout parts vehicle, it has a d44 with disk brakes. I haven't had the opportunity to check and see if the knuckles are flat top, if they are, are there any other considerations (I know the bolt pattern is the same), or will they for sure work? It would be GREAT if they did!
Old 02-25-2010, 04:36 PM
I dunno, you might actually interrupt the space/time continium putting Cornbinder parts on a FSJ.
Old 02-26-2010, 09:48 AM
Josh D's Avatar
Josh D Josh D is offline
Scout knuckles have really long steering arms due to outside frame mounted steering box and forward facing pitman arm. I've seen new holes drilled and tapered in the arms when swapped into CJ's. Other quirks are the 8 spindle studs (all others use 6, so spindles aren't interchangeable) and they use bolt on hublocks rather than internal spline hubs like the others. They also utilize their own axle stub shaft for this configuration. I don't think the Scout spindles will work with the Jeep hubs, which means you'd be stuck with all Scout stuff from knuckle out, including the 5X5.5 bolt pattern.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 02-26-2010, 09:53 AM
ksq2's Avatar
Appreciate the info. Josh, I realized I missed the bolt pattern after I posted that. Looks like I'll keep shopping.
flat top knuckles Pheinz General FSJ Tech 4 06-04-2008 06:59 PM
flat top knuckles trcooperone Off-Road FSJ Tech 2 06-07-2007 12:10 PM
SOA without flat top knuckles.... 83 chif Off-Road FSJ Tech 8 02-11-2007 10:12 PM
Flat Top Knuckles Golden Goose General FSJ Tech 1 04-05-2005 12:08 PM
8 lug flat top knuckles?? The Donzi Off-Road FSJ Tech 21 09-10-2004 03:18 PM
