  #41
Old 02-17-2007, 07:35 PM
79_Limited's Avatar
79_Limited 79_Limited is offline
Top bolt for the cover of the cover of the Quadratrac case. Ended up dropping the cross member just to get clearance.
Rusty & stripped torx bolts for the seat belts.
79 Wagoneer Limited Quadratrac Milemarker part-time conversion
New paint link: http://i20.photobucket.com/albums/b2...NewPaint26.jpg
Old 02-17-2007, 08:45 PM
Gambler68's Avatar
Rabble Rouser
I've torn down 2 (3 including the front of the 68 J3K) trucks..
trannys are simple to lower using a cherry picker shoved in the cab and lowering through the hump plate.
I'd say snapping rusty body bolts off kinda sucks. Hardest part about anything is figuring out how to do it with one person, and not end up a bleeding pile of flesh if you make a mistake. If I ever got hurt working on the truck, it'd usually be hours before anyone found me out there :P
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 02-17-2007, 08:53 PM
Brown Bear's Avatar
Brown Bear Brown Bear is offline
The thing that annoys me most is rhino grills...............
I'd say waterpump as most annoying, heater core second, root canal third.
NathanielButts
IFSJA Member #18
RIP-USS Minnow-The three hour tour is over.
MacGuyver - 1985 Grand Wagoneer
TFI, Edel Intake, Holley 80457S (yeah, it's shiney), K8600, K&N, Taylor Wires, Ford HD springs, and way freakin' cooooooool
Old 02-17-2007, 09:48 PM
my 2j20's's Avatar
my 2j20's my 2j20's is offline
Brown Bear vbmenu_register("postmenu_562138", true);
I agree here with Brown Bear! THAT I hate the water pump change...way to many parts & spacers too...
NathanielButts
IFSJA Member #18
Want to chat on IRC with the FSJ crowd, but don't want to install anything???
As yet unnamed 1985 Grand Wagoneer
Old 02-17-2007, 10:32 PM
710 Burner's Avatar
Having to go inside the G/D tailgate for any reason. I have been inside that thing 4 times. I have to admit the last time was my fault. You shouldn't reuse the spring clips that hold the arms to the window. They will get tired of you prying them off. I used an E-clip and a washer last time in, hope it holds.
Mark B. Jones
'79 Cherokee Chief "Junaluska"
Old 02-19-2007, 07:13 PM
GreenMachine's Avatar
GreenMachine GreenMachine is offline
I hate setting up ring and pinions.. And this one time I tried to replace the oil pump gasket that was leaking on a 360 and snapped off 3 of the bolts in it ( that was fun).
I don't mind Torx. I don't own a set of torx bits I just weld a nut to them and turn them out with a wrench and then never put em back. My wifes 91 Xj had one on the top of the transmission and I almost cut a hole in her floorboard trying to get it out. It was reverse torx though and just really really hard to get a wrench on.
GreenMachine
Old 02-19-2007, 07:26 PM
prayforsurf prayforsurf is offline
I'm surprised that you guys had trouble with the upper starter bolt, i never had a problem with that, and im terrible with that kind of stuff. the thing that had me ready to sell the jeep was the stupid fuel pump....maybe i was just having a bad day, and was being a little over cautious about crossthreading the bolt (i dont believe its possible to be overcautious with that kind of thing but w/e), but i couldnt hold the pump up and get the bolt in straight, i would always get a cramp in my forearm from the funky position and then it would make me lower the pump a frogs hair and disalign the holes.
as for the plug behind the heater core... i get that one from underneath, works awesome. i think we should have a competition, who can change all the plugs on their jeep properly and start her up.
88' Grand Wagoneer. Working on it piece by piece just keeping it running.
"Slow progress is sure progress"
Old 02-19-2007, 07:57 PM
jeepnhal jeepnhal is offline
body rust.i dont mind mechanical work(its stress releif for me)but i hate body work and i plain suck at it.unfortunately its unavoidable here in ct
1993 xj,35s,rubicon express this n that daily driver/wheeler
1977 waggy(plow king)
Old 02-19-2007, 08:02 PM
thejum57's Avatar
thejum57 thejum57 is offline
Don't even have to think about that one........the gas tank. I've had to drop it 3 times. All the lines, fuel, and air. The filler setup on a J-10 is un-freakin' beleivable to work on. Well it's still hard to fill it, and the guage still doesn't work. So, I guess it will come out a 4th time this year!
Jim, W.Mass. 1976 J-10 258/6 "short-bed" rebuilt motor, Webber 2bbl, Rancho 5000, C.B. 2M HAM, 30" high cap to fit over roll bar KB1FIT (sadly...sold)
http://i172.photobucket.com/albums/w...7/000_0747.jpg
2ooo Dodge Grand Caravan
1987 Chevy Cavalier Convertible
1986 Jeep Comanche
http://i172.photobucket.com/albums/w...7/000_1213.jpg
Old 02-19-2007, 11:47 PM
Am4wag Am4wag is offline
Installing 4in. lift kit (all 4 spring packs) in late November,1/2in. water on floor of shop (raining and leaking roof),by myself.
88GW,360,3 angled valves,K8600,1406,TFI,MSD,727,<br />Hurst,NP229.D44\'s,3:31\'s,BJ\'s 4in.,31in.Generals,ProComp alloys.S-10 box,"Swissed" rockers"
Old 02-20-2007, 04:09 AM
Wagoneerlover Wagoneerlover is offline
I have to concur with some of the other guys here. Getting them dagone body bolts out is a nightmare, that along with the exhaust manifold to y pipe bolts. I tried removing both sets of these bolts and they are designed to rust and break off as opposed to coming out. Another little easter egg that AMC/Chrycho left for us all!!!. I have been able to tackle the other projects (Fuel pumps, trans, starter top bolt etc.) With relative ease. maybe I am doing something right. Who knows. but the rear two bolts on my body mounts broke off and the others will definitely break as soon as I attempt to remove them. Too dagone cold right now to finish off the body lift but I guess when the weather breaks I will be using many four letter words putting in the body lift. Dang.
88 Grand wagoneer AMC 360 all stock
89 Grand Wagoneer AMC 360 (Deceased)
Upgrades
1. Electric Radiator Fan 10/15/11
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
Old 02-20-2007, 08:55 AM
zmjeeps's Avatar
zmjeeps zmjeeps is offline
Removing and installing FSJEarls truck trans for no good reason...
Zack
Zack Heisey
Z&M Jeeps
419.893.4JEEP (4533)
www.zmjeeps.com
zack@zmjeeps.com
Old 02-20-2007, 09:24 AM
FSJ-Earl's Avatar
FSJ-Earl FSJ-Earl is offline
Zack
I just wanted to make sure that you knew how to remove one and put it back in!
FSJ-Earl
2002 F350 Diesel - tow rig / family hauler
2008 4 door JK Rubicon - Wife's Daily Driver
1989 GW - the one that started it all
1983 - J15 - J10 body + J20 running gear = J15 Trail rig
Old 02-20-2007, 09:27 PM
Dome's Avatar
Dome Dome is offline
That **** vinyl power window track in the drivers side door that seems to break every 9 months like clockwork. Not the most difficult thing, but definitely one of the most annoying.
83 Wagoneer Limited (R.I.P)
360, TF727, NP228
SOA, 35's, WT Axles, 4.10 gears, Detroit Locker
Old 02-20-2007, 09:55 PM
Ranger's Avatar
Ranger Ranger is offline
I'd have to say I despise changing water pumps on AMC V-8's especially on rigs that are loaded with accessories.
Ranger
Currently--1974 J20 project, factory 401, TH400, HD44, D60
Various other parts FSJ's
Old 02-21-2007, 08:48 AM
zmjeeps's Avatar
Somebody forgot to mention that none of the bellhousing bolts were even finger tight...
Zack Heisey
Z&M Jeeps
www.zmjeeps.com
zack@zmjeeps.com
Old 02-21-2007, 06:10 PM
andy d andy d is offline
Shade Tree Shaman
lessee, gas tank, fuel and water pumps. 30' of vacuum hose and the dozen or so valves used to smog a 60s engine to 21st century dyno smog test specs. Electrics dont faze me, the location of the fuse box does. The assortment of fasteners: English, metric and Torx is a PITA. The oil pan and the Y pipe are fun too. On the whole, I'd rather wrench on my 528e. .
\'88 gwag,pure stock
Old 02-21-2007, 06:13 PM
INTAKE MANIFOLDS!!!!! Takin mine off for the 5th time in 3 months
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 02-21-2007, 06:39 PM
nw_upstart's Avatar
nw_upstart nw_upstart is offline
Having do do an engine rebuild and swap in a week in the early cold winter of January because you wrecked your other truck and needed a rig to drive. Spending countless hours doing this in the rain and mud with little to no sleep and a growing cold, only to not be able to connect the engine and tranny. Got through everything and was suddenly held up by a 1/2" gap.
Turned out to be the pilot bushing. Clutch kit came with 2, and the only difference was about a millimeter. It was a millimeter that made a huge impact however.
Other than that the back passenger valve cover bolt. **** heater core is in the way even when you're laying across the engine.
Meg - 1979 Cherokee WT, 360(Freshly built- upgraded most everything in it)/T18/D20, 3" lift, 33x12.5 BFG All-Terrain KO T/A, D44/D44 Detroit TrueTrac
1976 Cherokee Chief - 360/TH400
1978 Cherokee WT - 360/TH400
1985 AMC Eagle 4x4 stationwagon
Old 02-21-2007, 07:25 PM
AlsChopShop's Avatar
finding out that the exhaust is mounted to the quadratrac case was a fun treat, no wonder i couldn't get the t-case to drop after pulling the 4 bolts. oh and the nut that held that pesky exhaust bracket on was covered by the bolt that held the exhaust to said bracket.
also having to leave the front drive shaft attached to the t-case while you drop it because the crossmember hinders access to the driveshaft bolts, thats a fun one.
the top starter bolt is also a major pain.
come to think of it, the only thing that isn't a pain in the arse on these rigs is adding oil... but thats really two faced because you are always frustrated how much oil ya gotta add to these things.
and we're shocked that AMC never made it...
Al
99 Dodge 2500 4x4 - Cummins 24v
07 Mazdaspeed3 GT - Big turbo, 340whp
