what is the diffrence between np 229 and np 228 besides the viscous coupling...so if its the same can i just take the open diff out of the 228 becouse i got one for free and put it in my 229 becouse i cracked my viscous coupling
np 229 and np 228
Thats it. The 228 has an open diff and the 229 has a viscous coupling.David "If all else fails, read the instructions."
Chevelleguy is correct.Ethan Brady
www.bigscaryjeep.com
Just clean the case out real good, get all the gray goop out of it.
The 228 diff won't like that stuff.Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
I could have sworn that there was a slight difference in overall length between the 228 and 229 when I had them on a bench side by side. I seem to recall that the 228 was visibly shorter, maybe only 3/4". Direct swap, but minutely diferent. Was that in my head?Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
90 GW parts rig "Velma"
77 J10 parts rig "NoMo" (as in "no more Jeeps, Corey!")
94 YJ "Coop"
Past
88 GW "Hercules" (had to sell in '08, curious who has it now)
83 Wag parts rig "Shaggy" (used to build Herc, then scrapped)
73 J4000 (had to sell due to PCS in '07)
75 Cherokee "Jerry Lee" (sold in '13 because I'm an idiot)
74 Cherokee "Dino" (used to build Jerry Lee, then scrapped)
LOL, I guess it was just in my head! Good work.Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
94 YJ "Coop"
Past
