Can you get a torquey 401 on the cheap?
  • yossarian19
    • Nov 13, 2016
    • 402
    This sounds like a silly question even to me.
    I've got a 401. It needs head gaskets and possibly rings.
    What I want out of the Jeep is lots of low and mid range grunt.
    I live at 2500 feet, occasionally drive up to 7500, and it's steep on the way up. I want the Wagoneer to be able to haul the mail in any gear.
    I've read a handful of AMC build articles but they all seem to involve custom pistons, ported heads, and 500+ horsepower.
    I'd be totally happy with 300 horsepower if I could have 350-400 ft-lbs under 3500 RPM. Broad, flat, and high torque curve. That's what I'm after.
    So... how do I get from here to there?
  • SC/397
    • Feb 01, 2010
    • 1024
    If you already have a 401 you are starting out on the cheap!
    After that, it doesn't cost any or, not much more, than any other AMC engine build. If you don't want to put pistons in it, just cam it.
    There is no cheap magic dust that makes horsepower and torque.
    The Squeaky Wheel gets replaced in my world
    • yossarian19
      • Nov 13, 2016
      • 402
      Well, damn.
      When I tear the heads off I'll have them checked for straight, put springs & seals in them, clean up the castings a little & call it good there. Then I suppose I'll add a cam, lifters & timing set to it and be happy with whatever I wind up with.
      • SC/397
        • Feb 01, 2010
        • 1024
        If you have to put pistons in it, use cast 1971 pistons. It will bump the compression up a little.
        • Ristow
          • Jan 20, 2006
          • 17292
          Elgin 912 cam kit. offy equaflow intake. hedman headers and dual exhaust. it'll snap.
          Originally posted by Hankrod
          • Ristow
            • Jan 20, 2006
            • 17292
            yup. i'll be crackin' the wallet real wide on this one.:lol: pardon the cell phone pics,this build is so cheap i couldn't afford to burn the calories to walk into the house for the real camera.:eek: this will be a low buck overhaul,but it won't be cobbled. the goal is a cheap motor with plenty of punch. the block was already
            • joe
              • Apr 28, 2000
              • 22392
              Old hot rod adage: "Speed costs money. How fast you wanna go?"
              • yossarian19
                • Nov 13, 2016
                • 402
                I only want to do 75, but I want to do it going up a 15% grade at high altitude.
                What does that cost?
                • babywag
                  • Jun 08, 2005
                  • 10286
                  Not as much as you think, however first you need to tear it down and make sure the internals are ok.
                  Even a small cam, does wonders for the AMC.
                  Get the heads checked out/redone, throw an RV grind cam in it.
                  4bbl intake/carb or FI.
                  • joe
                    • Apr 28, 2000
                    • 22392
                    Maintaining 75mph pulling a 15% grade is "pretty optimist" and going to take some eng poop. Prolly gonna have to appropriately regear the axles to keep the motor in the powerband. But that's gonna blow the "on the cheap" thing out of the water. Heck even semi's with big hp/torque have to drop a few gears to pull a 15% grade. That's what the stir-stick is for, picking the right gear to keep the motor in the powerband, then sit back and grind your way up the grade best you can. I suggest you rethink your expectations. If you're not willing to do that you may as well toss in some more silliness like "and get 20 mpgs doing it"
                    Best of luck with the "on the cheap" plan.
                    • Nikkormat
                      • Jan 03, 2015
                      • 143
                      Man this should be easy. Floyd Hill here in CO is about that steep and with the mostly stock 401 I can pull it about as fast as traffic will let me.
                      Gearing will be important here, too.
                      • J20 project
                        • Dec 27, 2000
                        • 2487
                        Melling Mta 1
                        I used the Melling cam....about the same grind as a Edelbrock performer.
                        9.5-1 pistons, Holley truck avenger. Single plane manifold(I happened to have it so used it) , 2.25in exhaust, no headers.....3:73 gears.
                        Pulled very hard low end. Seemed to flatten out past 3K rpm...I didn't care about that.
                        FWIW, I broke two th400 cases w/ it......Kinda got extreme but broke them nonetheless.
                        Don't forget to make the darn thing able to coollll...It will make heat..need top notch cooling system.
                        J20 project
                        BP Drivetrain...........
                        775-537-7918
                        • alley oop
                          • Jul 20, 2014
                          • 35
                          360 reman
                          i just had my 77 360 reman by a shop in Spokane wa mostly stock with a few up grade, edelbrock performer manifold, holly 600 carb, custom ground cam, 30 over pistons, lower end was balanced with headers, when i went to pick it up i got to witness the dino test with the stock prestolite dizzy and was putting out 280 hp with 345 ft lb torque at 3200 rpm. it was built to pull a 4x8 trail full of camping/hunting gear, sense then i did more upgrade to the ignition, put in a 79 motorcraft dizzy, msd 6a box ,and a 84 ford big cap setup and tfi coil, only got about 100+ mile on it so i haven't push it to hard yet, did go on a test drive and it had no problem pulling a 4% hill in 4th gear at 60 mph and not even close to 3200, I have the build sheet with the part list and the dino sheet if you want to look it over sent me a message i try to get the posted, as far as cost not cheap $2300 for reman with 5yr 50,000 mile warranty plus $$$$$$$$$$$$$$$$ for other upgrades
                          • J20 project
                            • Dec 27, 2000
                            • 2487
                            Fwiw...I used a 71 approx. 9.5-1 short block....76, dogleg heads, Melling Mta-1 cam....
                            I broke two...not one,.two th400 bellhousings.
                            3:73 gears, 34 in mudgrips.
                            How's that for torque????
                            J20 project
                            775-537-7918
                            • mattmopar440
                              • May 17, 2007
                              • 4092
                              the Ristow 401 I got was a monster below 3,000 never had a lack of power towing
                              87' Grand Wagoneer
                              80' J10 4BT/AX-15/208
                              74' J10 Go Grabber Green Sold
                              Originally posted by Heavy_Metal_Thunder_81
                              Inferior Chevy
