Rancho front spring questions
  • skeletor
    • Jan 31, 2006
    • 1360
    On my j10, the front springs are dead and inverted. The rear springs are ok, I'd like to lift it about 2.5 - 3" because I want a lower ride height, I actually use the truck for hauling stuff, and I feel a 4" kit is too tall, plus with a 2.5 inch lift I could easily run 33s.
    So enough of the excuses, what I'm thinking of are rancho 44044s up front and maybe get some rear rough country springs out back or 2.5" blocks. Or just get a rough country kit and take some leaves out? Any other ideas?
    1984 j10 LWB - for sale
    1977 Cherokee chief wide track(sold)
    2004 LJ - sold
    2021 Jeep Gladiator Willys
  • rang-a-stang
    • Oct 31, 2016
    • 5512
    yep! I ordered this kit and plan to install it sometime in the next 2 weeks.
    2.5" of lift, better ride, gotta love it. You'll still neeed new springs though. I have a set of these to go on, too.
    there are other replacement springs out there but I found mine on Craigslist for cheap so that made the decision for me.
    Chuck McTruck 71 J4000
    (Chuck McTruck Build Thread)
    00 Baby Cherokee
    • skeletor
      • Jan 31, 2006
      • 1360
      What are you doing about the rear springs though? It's either gonna be blocks (not a huge fan) alter some lift springs or custom springs, or I guess a rear shackle flip...what I'm trying to find out is the easiest method
      2004 LJ - sold
      • rang-a-stang
        • Oct 31, 2016
        • 5512
        mine has blocks already from the previous owner. I am comfortable with them becuase they are just little 2"ers. Rocklaurence also has an FSSR kit that comes with some quality blocks. Look around on his website. He frequents IFSJA.org often...
        00 Baby Cherokee
        • fsj454
          Long time member
          • Jan 02, 2015
          • 521
          New Springs in Front
          I will be putting new springs in the front of Top Secret .The bigest that rancho makes .Because my crossover steer looks like it was hitting oil pan on motor and that could kill a motor.I had mocked these spring before but to high but now i need all i can get.Wish me luck.....Over 10 inches of lift
          1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
          • ZackN920
            • Nov 18, 2015
            • 945
            I love my 44044's! I've read though, that you don't want them sua if you are going to do some serious, harsh off roading. I've seen plenty of pictures of bent main leafs.
            I'd vote to get new springs for the back, since it's a truck, and you plan to use it as such. I don't see blocks being too good, under a lot of weight in the bed.
            Now, to get away with it for awhile, put some air shocks under it. That's what i've got holding the back of my wagon up with at the moment.
            I wonder if Rancho has a set of springs for the rear that would match well with the 44044's up front? I havnt seen of it yet so, idk...
            What I do know, is that a local spring shop has a set of new GW rear springs, for what sounded like a reasonable price...But, those were for stock replacement. I'm sure if I got back to him, he could probably get a long aal for each set to get them up a bit more for me...But that's waiting for now, until I know when I need to get that gas tank out
            1990 Jeep Grand Wagoneer-"Big Jeep"
            ...in pieces for more rust repair...
            • CutterN55
              • Mar 09, 2009
              • 1141
              From what I've seen, most of what you'll find available for 2" - 4" lift height from most of the main stream companies is blocks out back or a combination of 2"blocks and 2" lift springs. It's hard to find anything under a 4" lift that is all spring.
              Now, as long as you aren't getting too crazy, blocks are fine. The biggest issue to watch out for IMO is axle wrap or cheap blocks cracking.
              **** I guess I'm talking out of my rear end. I see there is now much less availability then there used to be****
              ROMANS 12:1-2
              '89 GW deceased
              Ford 4spd swap Np435/205
              • ZackN920
                • Nov 18, 2015
                • 945
                So, who sells just a rear set of 2" springs?
                • CutterN55
                  • Mar 09, 2009
                  • 1141
                  Call Alcan
                  ROMANS 12:1-2
                  '89 GW deceased
                  • serehill
                    Gone,Never Forgotten.
                    • Nov 22, 2009
                    • 8619
                    yeppers
                    Blocks suck
                    New more arched front springs & old stock springs with blocks are really bad. Hard front soft rears. Think about it. Any lifted spring is more arched & stiffer. Even the so called soft rides. Highly arched front springs & less arched back spring are dangerous on rough roads. Blocks also increase the possibility of spring wrap especially when towing.
                    80 Cherokee
                    360 ci 727 with
                    Comp cams 270 h
                    NP208
                    Edlebrock performer intake
                    Holley 4180
                    Msd total multi spark.
                    4" rusty's springs
                    • fsj454
                      Long time member
                      • Jan 02, 2015
                      • 521
                      Rancho
                      OK Put springs in .All good now .Ride is not bad .Steering wheel is not in center and need front end alignment.28 1/2 to bottom of bumper
                      • ZackN920
                        • Nov 18, 2015
                        • 945
                        Fix them issues yourself, instead of wasting the money. I found that it's not that hard.(thanks to the help of another member here) Don't know why you need an alignment now though. I didn't need to mess with it, until I changed my loose driver side tie rod end.
                        Unless you think it needs it becuase the steering wheel is off. Just adjust the adjusting sleeve on the tie-rod that attaches directly to the steering box... or if it's rusted up like mine, replace then adjust. That will get your steering wheel straight.
                        • rang-a-stang
                          • Oct 31, 2016
                          • 5512
                          What was it before?
                          00 Baby Cherokee
                          • fsj454
                            Long time member
                            • Jan 02, 2015
                            • 521
                            Death Wobble
                            I think I need front end alinmant because I am getting death wobble at 25 mph.people say you do not get death wobble if you have a rock ram I have a rock ram .All new parts used on dana 60 front every thing new .NEED HELP ......
