Old 10-17-2007, 10:26 AM
AKAMC's Avatar
AKAMC AKAMC is offline
Twin stick shifter for 229???
Anyone out there ever fab one or is there one avalable the the FSJ t-cases? I'm looking for one I can use in an Eagle with an 86 228 t-case I swaped in. Needs to work with a t-5 tranny. Photos of any custom fabed shifters would be great too. Looking to get rid of teh vacume 2/4 dash shifter. I have the hi/low shifter from the 86 but would like to see if I can get a twin stick to work first...
06 Rubicon Wifes toy
84 CJ8
66 Amphicar Yea it's a boat too!
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
19XX Sexy Red Head loaded with all the options!
ALASKA... "Land of the Individual and Other Endangered Species"
Old 10-17-2007, 11:27 AM
Wagonforever's Avatar
Wagonforever Wagonforever is offline
Well since the 229 uses a Viscous clutch and the 228 has some sort of differential, there's really no direct drive to the front wheels unless your in 4lo. So you really can't run just the front wheels independently of the rear. I think you'd be wasting your time, you'd be better off using a different T-case for a twin stick conversion.
Or do you mean simply that you want to get rid of the vacuum switch and have a leaver for 2wd-4wd?
There are those that have and those that will.
1986 Grand Wagoneer, BONE STOCK just the way I like em!
The Aviation Forum
Fred 08
Old 10-17-2007, 11:43 AM
AKAMC's Avatar
Thats basicly it. I'm actually using a 228 with open internal diff non VC. The car has lockers front and rear and I drive on snow and ice alot up here so the t-case diff in the 228 will work great with that. The front axle has no disconect so it's full time anyway. I want to be able to shift in and out of 4wd on the fly with a lever when I'm in and out of ice around town. When I hit the trail I'll use the other lever in low range to lock the t-case.
84 CJ8
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
Old 10-17-2007, 12:07 PM
You now can shift on the fly between 2H/4H with the dash vacuum switch on an 86. Only years you couldn't do that was in 83-84 that required you to be stopped so the front vacuum axle could engage first. You don't have a front vac axle.
Old 10-17-2007, 12:14 PM
It would probably be easier to rig up a cable control for 2hi/4hi shifting than to try and stick another shift lever and linkage in there. If you have the vaco front axle, there are fairly easy ways to lock that sucker.
Old 10-17-2007, 12:16 PM
AKAMC's Avatar
Thats right. My Eagle is an 83 with an 80 Fulltime front axle. The vac system is gone and with the cold temps here in Alaska I don't want to use it and have the lines crack in sub zero temps. So rather then replace the vac system and install the under seat shifter I though I'd look into building a twin stick to run the t-case. I'm thinking a twin stick from a T-5 dana 300 CJ might be close. Just wondering if anyone else has tryed that on a 229 or 228 T-case.
84 CJ8
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
Old 10-17-2007, 12:19 PM
AKAMC's Avatar
It would probably be easier to rig up a cable control for 2hi/4hi shifting that to try and stick another shift lever and linkage in there. If you have the vaco front axle, there are fairly easy ways to lock that sucker.
Thought about that to but I've had them freeze up here after summer wheeling gets water in the cable and winter temps hit. I'm in the Fairbanks area and expect to see -25 alot... We hit -62 for 3 days two years ago...
84 CJ8
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
Old 04-14-2008, 11:56 PM
AKAMC's Avatar
I know this is an old thread but I thought someone here might want to try this on a 229 in a Grand. Worked great in my Eagle. I modified a twin stick shifter for a Jeep dana 20. Used teh vacume moters mounting brackets to mount it and cut the remounted the handles to fit. Left handle is 2 to 4 and right is high to low.
Not a true twin stick by teh Jeep defination but works so much better then that vacume crap and looks great to... Oh and I'm now running a 229. Had the 228 in for a bit and had to kick it to the curb...
http://norakor.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=3564& g2_serialNumber=2
84 CJ8
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
Old 04-15-2008, 04:36 AM
GWChris GWChris is offline
That is very cool!
Old 04-15-2008, 06:25 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Do you have more pics of the work you did to install the shifters? I'm thinking that this might be a good write up for the archives...
Old 04-15-2008, 08:01 PM
AKAMC's Avatar
I did one over on teh Eagles nest forum. Here's the link if anyone wants to have a look. Lots of info and photos. Should work with any tranny as teh mount I addapted was 229 specific.
http://forums.amceaglenest.com/index.php?topic=12861.0
84 CJ8
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
Old 04-16-2008, 07:04 AM
Elliott's Avatar
Cowboy Up
Cool
Old 12-17-2008, 01:39 PM
1974cj5 1974cj5 is offline
This is exactly what I have been looking for! awesome!
Old 06-03-2009, 06:19 PM
Dan Stewart Dan Stewart is offline
I coudlnt PM but thanks for the pics!! This would be easier than swapping out Tcases and front axles. Did you add locking hubs in the front on the IFS of the eagle or is it still a flange? Is there any binding?
Dan Stewart
1958 Land Rover Series 1
1991 Wrangler YJ
Old 06-03-2009, 08:47 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
Is there a link still available to the pictures of this mod? The links above no longer have photos.
I am not sure how I missed this thread. Granted, I was in Iraq, but still..
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP242, F150 fuel cell, discs, Aussie rear, LDS front, 4.10s
http://imgbox.com/g/rNuIasKYrS
95YJ, STaK 300, D44's, SOA, ARB's, 4.56s, Bilsteins, 35" KM2's
50 CJ3A
77 J-10, 360/T-18/D20, SOLD
Old 06-04-2009, 03:13 AM
Stumblinman's Avatar
Stumblinman Stumblinman is offline
Craig your crap has been moved around!!!!!!!!!! Send me a pic of it and I'm now thinking I could've used those flat tops now.
It's not the leaks that bother me, it's when they stop that makes me worried.
1988 Waggy SOA stretched, cut, Chevy R. 4" springs in front, shackle reversed, stock springs reversed in back, Edelbrock manifold and carb, mini-spooled front, lunchbox rear, currently on spaced 35s.
www.FairbanksOffroadLions.com
Old 06-04-2009, 09:16 AM
Yes, please fix the pics. I would like to see this also...
Thanks.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 12-30-2009, 07:13 PM
billyj7175's Avatar
Yes...I would also be interested in the pics...
83 J-10 Jeep "Oscar"
360/727/229
Old 12-30-2009, 07:37 PM
Here are the pics, I saved them.
Dan Stewart
1991 Wrangler YJ
Old 12-30-2009, 08:10 PM
tag187 tag187 is offline
This is beautiful
