Old 08-22-2012, 09:31 PM
nc wagoneer's Avatar
nc wagoneer nc wagoneer is offline
j10 max tire size
Ok, I was wondering what the largest tire is that you can fit on a stock j10 and the biggest tire you can put on a j10 with a 2 inch lift. I saw 35's on a stock j10 in another thread but I think they would rub I need the biggest tire without rubbing. Can I put 33's on with a 2 inch lift? By the way the 2 inch question is because I'm looking at a j10 with a 2 inch lift.
"BROWED AND PROUD"
Old 08-22-2012, 09:42 PM
j20owner's Avatar
j20owner j20owner is offline
I fit 33's on my j20 with stock springs. It didn't flex very much, but it didn't rub. I think you'd be fine with 33's and a 2" lift.
Where is my axle?
79 j20/84 GW GM Hybrid
Old 08-22-2012, 10:53 PM
Both my J-4600 and J-4500 (pretty much long wheelbase J-10's) with 'good' condition stock suspension ran 33x9.5's and never had a rub issue. I don't rock crawl but in the woods with associated bumps like water bars even with 3/4 cord of dry firewood loads never had a rub issue. With 12 wides I've heard you may have an issue rubbing on the springs at full lock but I dunno cause I don't do wide tires.
Old 08-23-2012, 12:04 AM
Cecil14's Avatar
Cecil14 Cecil14 is offline
33's will fit fine with a 2" lift. I wouldn't try any extreme flexing but overall you'll be fine. As Joe mentioned, if you run wider tires you'll need to adjust the steering stops a bit to prevent rubbing. Otherwise all is good.
aa
Old 08-23-2012, 10:53 AM
ktmracer419 ktmracer419 is offline
Coulda been me. It didn't rub, I could turn lock to lock, Didn't rub at max flex (granted, max flex isnt much on a stock truck)
Old 08-24-2012, 11:47 AM
33/9.50/15s on my Honcho bone stock.
Old 08-26-2012, 10:51 AM
lil jeep mec's Avatar
lil jeep mec lil jeep mec is offline
35 14 15 on the rear... havn't done any wheeling yet... im looking for 35 12.5 15's for the front first... i believe i have a 2" lift...
78 j10 4bbl 360 green on 35's
360, t18, d20, d44's, 4.09's
plan on...
-SOA
-37's in 2 or 3 years 40's-54's
-not cutting the flares
-get the 360 running
-twin stick
-OX lockers!
Another Tire Size Question: J10 The PIG Smith General FSJ Discussion 8 10-09-2011 10:37 PM
Tire size ? for M715 bed &front fenders HOOT General FSJ Tech 17 03-05-2011 10:47 PM
Max tire size with stock gears? rollie715 Off-Road FSJ Tech 11 02-08-2011 10:11 AM
Tire Size Choices for J20 tow rig The PIG Smith General FSJ Discussion 26 01-28-2011 06:19 AM
Maximum tire size that will fit stock J10 mw21032003 General FSJ Tech 13 02-03-2007 01:51 AM
