401 on dyno
  • jcisworthy
    • Apr 01, 2016
    • 43
    401 on dyno
    AMC 401
    511 HP / 500 TQ
    Heads
    ? ?Street Ported? factory iron with competition valve job
    ? 270 CFM @ .550 intake, 190 CFM exhaust @ .550
    ? Stainless steel 2.055/1.625 11/32 stem valves
    ? 7/16 screw in chrome molly studs and guide plates
    ? Bronze guides with positive viton metal clad seals
    ? Dual valve springs with machined 10* machined locks and retainers, spring seat locators
    ? Resurfaced plus intake and exhaust mounting surfaces milled
    ? Cometic head gaskets
    Block
    ? Painted base coat clear coat AMC P44A Caravelle Blue
    ? Bored and torque plate honed .030 to 4.195 final bore, 9.5:1 compression
    ? Line Honed with ARP main studs
    ? Decked
    ? Oil drain backs modified for better flow
    ? Main oil feed enlarged for more volume
    Crank
    ? Factory AMC 401 turned .010/.010
    ? External Balanced
    Rods
    ? Full floating Molnar with ARP 2000 bolts
    Pistons
    ? Wiseco ProTru pistons with Hasting moly rings, spiral locks
    Oiling System
    ? Ported and enlarged Factory AMC passages in timing cover / filter adapter
    ? Drilled and taped pressure bypass valve spring retainer cap screw with bolt installed for adjustable oil pressure
    ? New pump gears and spring
    ? New stock replacement oil pan
    Dampener
    ? New professional products
    Flex Plate
    ? New SFI approved
    Ignition System
    ? Pertronix III conversion installed in factory point style
    ? Fully reconditioned with locked timing set at 34* BTDC
    ? New brass contact cap, rotor
    ? New 7mm wires
    ? New NGK spark plugs
    Carburetor
    ? Holley HP annular discharge mechanical secondary
    Intake
    ? Ported Edelbrock Torker
    Cam, Lifters, Timing Chain. Rocker Arms, Pushrods
    ? Custom ground Bullet Cams solid flat tappet with Johnson Hylift EDM lifters
    ? 260/274 advertised, 234/244 @ .050 duration, hot lash .016
    ? .3600/.3380 lobe lift, .576/.541 gross valve lift
    ? 110 LSA, intake lobe degreed to 106
    ? 1.6 stainless steel roller rockers
    ? Double roller
    ? New cam gear
    ? Pushrods, 5/16 chrome moly .080 wall thickness
    Video Links
  • jcisworthy
    • Apr 01, 2016
    • 43
    Link to dyno sheet
    Ran the latest 401 on the dyno today 511hp 500 tqHeads· “Street Ported” factory iron with competition...
    • babywag
      • Jun 08, 2005
      • 10287
      awesomeness!
      • rang-a-stang
        • Oct 31, 2016
        • 5512
        GET IN MY BELL EH! er... I mean
        GET IN MY CHERO KEH!
        Who did the head work?
        Chuck McTruck 71 J4000
        • mattmopar440
          • May 17, 2007
          • 4092
          Holy power batman 1hp per Cubic inch and I would be happy but 500 hp
          87' Grand Wagoneer
          401/727/229, Currently:RUNNING
          84 J10/20 hybrid 258/727/208 Daily Driver
          80' J10 4BT/AX-15/208
          74' J10 Go Grabber Green Sold
          Originally posted by Heavy_Metal_Thunder_81
          Inferior Chevy
          • jcisworthy
            • Apr 01, 2016
            • 43
            Dont know if it is ok to say it here but the engine is for sale if anyone is interested.
            • babywag
              • Jun 08, 2005
              • 10287
              Fine to mention, but you should also list it in the for sale section for more visibility.
              • SC/397
                • Feb 01, 2010
                • 1024
                Nice! Gotta love a Torker and a nice cam
                • jcisworthy
                  • Apr 01, 2016
                  • 43
                  Thank you. The torker has always worked well for me.
                  An air gap would probalby work for this application also but I had two torkers so I used one.
                  • Jeepyz
                    • May 29, 2018
                    • 7
                    That's great. nice one!
                    • jcisworthy
                      • Apr 01, 2016
                      • 43
                      Thanks
                      The engine went a best of 10.60 in an AMX that weighs 3000 lbs, I believe, with driver in it
                      It was killer air and a tail wind also. Runs 10.8-10.9 typically
                      AMX is a drag car only
                      • Jpzyr
                        • Sep 03, 2018
                        • 8
                        Cool!
